POV-Ray : Newsgroups : povray.bugreports : file directory problem : Re: file directory problem Server Time
28 Mar 2026 15:40:19 EDT (-0400)
Date: 8 Apr 2019 12:15:00
Message: <web.5cab733e1c4d9672968d6dc0@news.povray.org>
hi,
Le_Forgeron <jgr### [at] freefr> wrote:
> Le 08/04/2019 à 01:04, jr a écrit :
> > Stream output files must reside in same directory as image output file.
> Basic problem due to IO restrictions being active (default).
> Well, not a real problem, works as intended, to protect the innocents.
fingers crossed.  :-)
> see ...
> So, as the message can be read: your log file must be in the same
> directory as the image output file.
> you need to tune the configuration of the io-restrictions to be more
> relaxed.
so this is the private 'povray.conf':
; POV-Ray 3.8
[File I/O Security]
restricted
[Shellout Security]
allowed
[Permitted Paths]
read* = /usr/share/fonts/local
read* = %INSTALLDIR%/include
read* = %INSTALLDIR%/scenes
read* = %INSTALLDIR%/extra
read+write* = /tmp
read+write* = %HOME%
and /tmp and its descendants work.  usually.  what needs to be relaxed?
regards, jr.
