POV-Ray : Newsgroups : povray.bugreports : invalid handling of funky Image-Ratio : Re: invalid handling of funky Image-Ratio Server Time
18 Apr 2026 15:26:48 EDT (-0400)
Date: 24 Dec 2018 18:10:00
Message: <web.5c21670a683b50b48892b50@news.povray.org>
"jr" <cre### [at] gmailcom> wrote:
> "Q0X" <nomail@nomail> wrote:
> > > > invocation with
> > > > povray +W1920 +A exp1.pov
> > > > scene is
> > > > camera {
> > > >     location <0, 10, -8>
> > > >     look_at  <0, 0,  0>
> > > >     right x*1.0/1.0
> > clipka <ano### [at] anonymousorg> wrote:
> > > Am 23.12.2018 um 22:42 schrieb Q0X:
> > > > Right - I forgot to tell that it crashes consistently.
> > > > It should at least exit gracefully.
> > > Well, I'd call that more than just "funky" ;)
> > > What version are you using? (Please be as precise as possible.)
> > Persistence of Vision(tm) Ray Tracer Version 3.7.0.4.unofficial (g++ 7 @
> >  x86_64-pc-linux-gnu)
> > This is an unofficial version compiled by:
> >  Andreas Beckmann <anbe at debian dot org> for Debian <www.debian.org>
> >  The POV-Ray Team is not responsible for supporting this version.
> in case it matters, the above "scene", cut + pasted, with the same command-line,
> runs fine (just warnings) with 3.7.0.8.unofficial on x86_64-slackware-linux-gnu.
heh, cheated and got found out.  :-)  I did render with +w400 -- the only
change, and things appeared fine.  but checking the output image size, it's
400x600.  so I tried again, this time with +w1920, and now 3.7.0.8 too crashes:
[xcb] Unknown request in queue while dequeuing
[xcb] Most likely this is a multi-threaded client and XInitThreads has not been
called
[xcb] Aborting, sorry about that.
povray-3.7.0.8: xcb_io.c:165: dequeue_pending_request: Assertion
`!xcb_xlib_unknown_req_in_deq' failed.
Aborted
regards, jr.
