POV-Ray : Newsgroups : povray.bugreports : Right-click menu in Windows Explorer : Re: Right-click menu in Windows Explorer Server Time
14 Mar 2026 18:47:33 EDT (-0400)
Date: 21 Jan 2018 16:20:01
Message: <web.5a65038bf442417e6080ff20@news.povray.org>
> Am 21.01.2018 um 18:09 schrieb Mike Horvath:
> > Weird issue with
> > Persistence of Vision(tm) Ray Tracer Version
> > 3.8.0-alpha.9475849+av541.msvc14.win64
> > and maybe earlier.
> > In Windows explorer I can select two POV files, then right click on one
> > of them and select "Edit in POVray". However, two separate instances of
> > POVray are created, with one file in each.
> > if you instead select three (or more) POV files and "Edit in POVray",
> > all three files are opened in the same instance.
> Can't confirm here (Windows 10 build 1709): I get the same behaviour
> regardless of the number of files opened (both 2 and 3 tested); I do get
> different behaviour depending on whether "Keep single instance" is on or
> off (and the behaviour is as to be expected from that setting).
> Didn't test with exactly the same version as you did, but there
> shouldn't be a difference.
Here Pov-Ray opens twice if it is'nt running. I have set "keep single instance".
But i never used it that way to open files.
