POV-Ray : Newsgroups : povray.bugreports : aspect ratio cannot be manually set : Re: aspect ratio cannot be manually set Server Time
1 Apr 2026 16:44:31 EDT (-0400)
Date: 29 Apr 2017 16:40:00
Message: <web.5904f941c2628cde944c3db40@news.povray.org>
"jmichae3" <jmi### [at] yahoocom> wrote:
> I have a dual-monitor setup, once it was a 3-monitor setup.
> so I wanted to make desktop wallpaper. I knew width had to be 3x, so I tried it,
> and I got vertically squeezed images. so I know the aspect ratio is wrong. it's
> /still/ 16:9 despite 3 monitors.  and after looking in the manual, there is no
> way to set the aspect ratio manually (would prefer it be in the .ini).
> so I looked at panorama shot. those little box cams do that. but the method used
> by pov needs to be improved. but I did get my sign finished, for now, and POV is
> nice to have.
I found out you can manually set aspect ratio, with up and right in the camera.
