POV-Ray : Newsgroups : povray.bugreports : Possible JPEG file output in Povray 3.7 : Re: Possible JPEG file output in Povray 3.7 Server Time
24 Mar 2026 22:49:45 EDT (-0400)
Date: 26 Jan 2015 06:35:00
Message: <web.54c6256944a07e55a2b638bc0@news.povray.org>
> Am 25.01.2015 um 09:18 schrieb Ken Shumway:
> > When I try to output in Jpeg format, I get this error message:  JPEG parameter
> > stgruct mismatch: library thinks size is 372, caller expects 376 Render failed.
> >   I am running with Ubuntu Linux 10.4. The screen output from Povray includes a
> > statement that the support library LibJPEG 62 with a Copyright date of 2013 is
> > used.  Is there a library that needs updating to fix this problem?
> If you're using the Ubuntu pre-built povray package, please contact the
> corresponding Ubuntu package maintainer for support; it should be their
> job to make sure that the POV-Ray package contains all the relevant
> dependency information to also install the matching libjpeg version.
> If you're using POV-Ray compiled from source, theoretically all you'd
> need to do is make sure that you have matching libjpeg and libjpeg-dev
> packages installed when you configure and build POV-Ray. (Do NOT try to
> use the libjpeg sources coming with the POV-Ray source; it's only
> included to build POV-Ray for Windows.)
Thank you for your help.  I decided it was finally time to upgrade my OS.  Works
great now.
