POV-Ray : Newsgroups : povray.bugreports : Animations. malloc(): unsorted double linked list corrupted : Re: Animations. malloc(): unsorted double linked list corrupted Server Time
15 Mar 2026 22:11:40 EDT (-0400)
Date: 6 Apr 2025 08:44:23
Message: <67f27727$1@news.povray.org>
If it is indeed a bug, you should be able to reproduce it if you enable
memory debugging by defining the various macros in pov_mem.cpp (in
particular MEM_GUARD) when compiling POV-Ray.
The other, and more likely, option - if this only occurs during long
renders - may very well be memory corruption due to overheating
problems. Nowadays this also tends to be a problem for memory due to
overall heat being generated.
Thorsten
On 06.04.2025 09:09, William F Pokorny wrote:
> Posting as a hook so others who might see this failure can find it and
> provide information.
> If you have seen this issues or have just hit it, please post here -
> along with environment, running conditions, frequency, etc.
> In the last six months or so I've been using the animation facilities in
> POV-Ray (yuqk) more than ever. Sometimes to create actual animations,
> but more often as a way to explore feature options. Or, as with the
> text{} object recently, to run down some crash already, infrequently,
> seen in non-animation (single frame/image) renders.
> Today, for the second time in the last month, I had a long running
> animation core dump with a "malloc(): unsorted double linked list
> corrupted" error(*). Both times the animation frames, rendering was
> working in the background while I was doing other interactive work. Both
> times the animation completed without issue once resumed.
> I'm kicking off some intentionally long running (many frame) dummy
> animations trying to trip this error while running my debug compile. I'm
> hoping to capture an annotated core dump file. Maybe I'll get lucky, but
> I doubt it. I guess something like valgrind an option - if I find myself
> really motivated.
> Linux. x86-64. My yuqk, v3.8 based fork releases R19 and working state,
> R20 code. Both times the scenes were small - with memory requirements
> <100MB.
> lsb_release -a :
>      No LSB modules are available.
>      Distributor ID: Ubuntu
>      Description:    Ubuntu 24.04.2 LTS
>      Release:        24.04
>      Codename:       noble
> g++ --version : g++ (Ubuntu 13.3.0-6ubuntu2~24.04) 13.3.0
> ldd --version : ldd (Ubuntu GLIBC 2.39-0ubuntu8.4) 2.39
> uname -r      : 6.8.0-57-generic
> Bill P.
> (*) - The error message comes from glibc prior to things crashing.
