POV-Ray : Newsgroups : povray.bugreports : uv_mapping bug on cylinders : Re: uv_mapping bug on cylinders Server Time
23 Mar 2026 00:56:13 EDT (-0400)
Date: 3 Aug 2022 18:21:00
Message: <62eaf4cc$1@news.povray.org>
On 8/3/22 10:44, Chris R wrote:
> "Chris R" <car### [at] comcastnet> wrote:
>> I encountered an issue with v3.8 beta 2 using uv_mapping textures on cylinders
>> while creating a label for a bottle.  I did search through the newsgroups for
>> any other report of this and didn't find anything that matches my problem.
>> The original texture is fairly complex and involves using an object pattern with
>> a text object as the "object" and fully-specified textures for the ink and the
>> background of the label as the texture list.  However, I was able to simplify it
>> considerably to the following:
>>              cylinder {
>>                  <0, 0, 0>,
>>                  <0, 20, 0>,
>>                  5
>>                  texture { uv_mapping pigment { brick color rgb 0 color rgb 1 } }
>>              cylinder {
>>                  <0, 0, 0>,
>>                  <0, 20, 0>,
>>                  5
>>                  translate <20, 0, 0>
>> As you can see, the second cylinder is translated after applying the texture,
>> but if you look at the brick pattern, it appears the uv_mapping is being applied
>> to the translated object first, because the bricks do not line up.
>> In my bottle example, the text doesn't show up at all in the translated bottle,
>> because the entire bottle is outside of the text object's boundaries after it is
>> translated.
>> -- Chris R.
> Just as additional information, adding a "translate <20, 0, 0>" after the
> pigment declaration in the second texture corrects the problem.
> -- Chris R.
IIRC the uv_mapping feature for cylinders and cones(a) is currently
disabled in recent v3.8 / v4.0 code. I believe you are getting some sort
of default planar mapping(b).
(a) - And other shape(s) where mapping didn't exist in v3.7.
(b) - Unsure what corrections for transforms and mapping spaces might be
getting done or not with it. You could roughly test for planar mapping
by moving the right cylinder in x by 5+1e-6, say.
More if interested. As remembered by my old flaky memory...
Cylinders and some other shapes did not previously support uv_mapping in
v3.6/v3.7 though the keyword was allowed by the parser with no warning
it's not really working. Jerome added code to do the mapping for
cylinders, cones and other shape(s).
Christoph, later found a longstanding issue related to unstable mapping
orientation - and he disabled all the new to v3.8/v4.0 uv_mapping
updates. The problem noted exists for older mappings too, like the ovus,
but it had uv mapping in v3.7 and Christoph decided to leave it as is
for v3.8.
Last I knew, the documentation reflects the uv mapping as it was with
the new uv_mapping shapes and not the current code state.
Jerome proposed fix for Christoph's concern, which I think is in
hgpovray38, but I've not looked at it in detail. It wasn't
adopted/merged in the official code.
Aside: I 'sort of' understand Christoph's concerns and Jerome's
proposal, but I have additional questions relating to shapes like
spheres which the parser 'sometimes' flattens to an already transformed
position/orientation. I'd guess any better uv_mapping specification/code
would have to track/work with the parser to maintain any specified
uv_mapping orientation there too.
Aside 2: There are two additional ways to do cylindrical mapping of
textures via warps and image_maps.
Bill P.
