POV-Ray : Newsgroups : povray.bugreports : bump maps inverted in spherical warp : Re: bump maps inverted in spherical warp Server Time
24 Mar 2026 16:52:03 EDT (-0400)
Date: 6 Aug 2021 07:35:59
Message: <610d1e9f$1@news.povray.org>
Am 06.08.2021 um 02:20 schrieb William F Pokorny:
> If I comment that last warp{}, and un-comment two warp{}s above - or use
> instead the plain pigment inside the texture with the warp{}, I get no
> complaint about any 'pointless' warps(a) - though some of them certainly
> are.
The primary reason is that textures - in general - are nothing but mere
containers to bundle pigments, finishes and normal perturbations into a
coherent unit. As such, they provide no functionality of their own.
Specifically, they have no "hook" built into them to plug a warp into.
Exceptions to the rule are patterned and layered textures, which both
add extra functionality of their own. And patterned textures do provide
a "hook" for a warp to plug into.
Yes, in theory we could have non-patterned textures propagate any warps
to their pigments, finishes and normals. We mustn't do that for
patterned textures though. Also, what should happen if the pigment,
finish or normal already has a warp? Should the texture warp be ignored,
appended, prepended, or override the pigment/finish/normal warp? What
should happen in this context to things that may or may not be converted
into warps under the hood, such as turbulence?
It would also mean that we'd have to add room for extra data to the
generic texture data structure, at least during parsing, because we
can't propagate the warp before the scene has been fully assembled: The
texture could be re-used someplace else and the pigment replaced with a
different one, for instance, in which case that new one would also have
to have the warp propagated to it.
And currently we're using the same data structures for both parsing and
rendering, so any extra memory we reserve for the parsing step is also
memory that will be unavailable during the render proper for other
stuff, such as storing image data, radiosity samples, photon maps and
the like. It would also be unused memory sitting right in the middle of
other data we might need frequently, potentially displacing useful data
from the CPU caches and thus maybe even dragging down performance.
TL;DR: I think there are too many worms in that can to open it up
without need.
