POV-Ray : Newsgroups : povray.bugreports : bump maps inverted in spherical warp : Re: bump maps inverted in spherical warp Server Time
31 Mar 2026 18:36:41 EDT (-0400)
Date: 5 Aug 2021 05:42:34
Message: <610bb28a$1@news.povray.org>
On 05.08.2021 09:28, Kenneth wrote:
> "pkoning" <nomail@nomail> wrote:
>> ...the parser complains that the "warp" modifier is not expected.  See
>> attached.
>> Possible Parse Error: Unmatched {
>> Parse Error: No matching }, warp found instead
> By the way: As Clipka pointed out in a another recent thread, those "unmatched
> {" warnings/errors are sometimes 'generic', in that they simply flag some kind
> of 'possible' error that isn't clearly known to the parser. Yeah, it's kind of
> confusing sometimes, to figure out what the true problem is. ;-)
Actually, the reason this is called "possible error" (my naming back
then) has to do with the message driven changes to output from POV-Ray
3.5 onward. Before, the parser would simply output to a text stream, so
it was perfectly feasible to output some text somewhere and the next
line would make sense out of it (from the user's perspective). However,
there might be a long and complex call chain of internal parser
functions between the place that detected the likely error and the place
that actually knows it is an error.
In modern integrated development environments (IDEs) it is at last
handled much better because the parsers hand them a full trace of all
the steps they took to get where they are and the user gets a kind of
trace where the parser went with each step and what it expected or
allowed. So yes, error reporting evolved over the last 15 years. But it
would require a very well structured parser, which POV-Ray doesn't have
due to its age (and no, it is not easy to rewrite either, nor is it a
beginner's task).
Thorsten
