POV-Ray : Newsgroups : povray.bugreports : alpha.9945627 "Constant" rounded : Re: alpha.9945627 "Constant" rounded Server Time
7 Apr 2026 00:31:18 EDT (-0400)
Date: 29 Jul 2021 08:56:32
Message: <6102a580$1@news.povray.org>
Am 29.07.2021 um 13:50 schrieb William F Pokorny:
> On 7/29/21 7:05 AM, clipka wrote:
>> On a related note:
>> - Multiple `Declare=...` settings in an INI file will not work as
>> expected. Only one value will come through.
>> - Using `Declare='Foo="..."'` cannot be used to declare an empty
>> string. Trying to do so will give a string containing `"` (a single
>> instance of the double quote character).
> Good catch. I just did see notices for your new issues. I did some
> testing with multiple and mixed declares on the command line and those
> worked OK, but only simple single declares for ini testing - I don't use
> ini files myself except when working to debug a scene from someone else.
Multiple declares on the command line should also be non-functional,
with only the last setting "surviving".
I didn't actually test them in an INI file, but on the faux command line
on the Windows interface.
