POV-Ray : Newsgroups : povray.bugreports : Parse error: Uncategorized error thrown at parser/parsertypes.cpp line 62 : Re: Parse error:Uncategorizederrorthrownatparser/parsertypes.cppline62 Server Time
23 Mar 2026 00:56:13 EDT (-0400)
Date: 21 Mar 2020 13:07:09
Message: <5e7649bd$1@news.povray.org>
On 3/26/19 6:46 AM, William F Pokorny wrote:
> On 3/25/19 7:41 PM, clipka wrote:
>> Am 25.03.2019 um 23:55 schrieb clipka:
>>> If `Cond_Stack.back().PMac->endPosition == CurrentFilePosition()`
>>> throws an exception, it means either of two things:
>>> (A) The positions compared are from two different files, which means
>>> the calling code has failed to check whether it is even in the right
>>> file.
>>> (B) The line/column tracking is buggy, and yields different positions
>>> in different situations.
>> Well, looking at the code of `IsEndOfInvokedMacro()` again, it
>> _strongly_ reeks of scenario (A):
>>      return (Cond_Stack.back().PMac->endPosition ==
>>                  CurrentFilePosition()) &&
>>             (Cond_Stack.back().PMac->source.fileName ==
>>                  mTokenizer.GetInputStreamName());
>> should probably be swapped around, like so:
>>      return (Cond_Stack.back().PMac->source.fileName ==
>>                  mTokenizer.GetInputStreamName()) &&
>>                  CurrentFilePosition());
>> so that the `LexemePosition` comparison operator is only invoked if
>> the file names match.
Documenting that Christoph's suggested code change up top, which fixed
the bug with Warren's original test case and related test cases I
created, is NOT in the v38 master branch as of commit 74b3ebe0 (March 8,
2019).
Christoph - I think - planned to fix the core issue, but this has not
happened as of today so the bug persists.
Bill P.
