POV-Ray : Newsgroups : povray.bugreports : sphere slicing problem : Re: sphere slicing problem Server Time
18 Mar 2026 13:45:56 EDT (-0400)
Date: 2 Nov 2019 03:38:10
Message: <5dbd3262$1@news.povray.org>
On 11/1/19 1:39 PM, William F Pokorny wrote:
> On 11/1/19 10:16 AM, jr wrote:
>> I now think that if, perhaps, there is a relatively simple and
>> accurate way of
>> calculating camera parameters for both camera types such that the
>> object is seen
>> in exactly the same size/position, perhaps one could merge the
>> results.  any
>> thought(s) welcome.
> Maybe...
Woke up this morning with a thought. If you're willing to render each
sample as three frames your idea might fly using two perspective cameras.
While in general using whatever you are using set up wise for best
results:
Using a perspective camera down in the first frame of a sample; A
perspective camera up in the second frame of a sample; In the last frame
use the results of the of the first two sample frames for planar
pigments which themselves would be used in a user defined pigment
applied to a plane with no lights but an ambient 1 finish and an
orthographic camera.
In frame 3/3 of each sample in the scan the user defined pigment would
be something like:
#declare PigmentMaxUpDownPerspective = pigment {
     user_defined {
         function { max(FnUp(x,y,z).r,FnDown(x,y,z).r) },
         function { max(FnUp(x,y,z).g,FnDown(x,y,z).g) },
         function { max(FnUp(x,y,z).b,FnDown(x,y,z).b) },
There is planar-position distortion due the perspective camera. You
would want to keep the angle small(1) to limit this. Further for each
sample the up / down cameras should be equal distance to the middle of
each sample's slice. In other words, the camera positions should be
based upon the middle of each sample slice.
Aside: A user defined perspective camera simultaneously up and down an
option too - say alternating rows at twice the vertical height - could
be rendered in one frame. You'd have to be willing to scale down
vertically only with some post render program/process.
Bill P.
(1) - Small perspective camera angles will tend to work against you in
being more parallel - more like the orthographic - some balancing
required. Small perspective camera angles also require the camera be
further away. So, I'll also mention there are accuracy issues especially
with higher order polynomial shapes when the camera rays start far away.
The accuracy issue is improved if you use my updated solver branch, but
still significantly present. The sphere is essentially order 2, so with
it your OK accuracy wise even at large distances away for the camera.
