POV-Ray : Newsgroups : povray.bugreports : hidden plane issue : Re: hidden plane issue Server Time
13 Jun 2026 02:33:28 EDT (-0400)
Date: 25 Jan 2019 10:35:14
Message: <5c4b2cb2@news.povray.org>
On 1/25/19 6:13 AM, gnagflow wrote:
> Hi,
> although hidden behind the red plane, parts of the blue plane can be seen
> from the following location.
> -------------- cut here ----------------------------
> #version 3.7;
> global_settings {
>    assumed_gamma 1.0
> camera {
>    perspective
>    location     -1 * <0, 1, 1/50000>
>    direction     1 *  y
>    look_at            y
> light_source
>      <0, -1, -1>
>      color red 1.0  green 1.0  blue 1.0
> plane { z, 0
>    pigment{
>      color rgb <1, 0, 0>
> plane { z, 1
>    pigment{
>      color rgb <0, 0, 1>
>    finish {
>      ambient  1
>      emission 0
> The effect was discovered on Linux kernel 4.20.2 with x86_64 GNU/Linux
> architecture using POV-Ray 3.7.0.8.unofficial version but can pretty much be
> reproduced on any system as far as I can tell. Accept my apologies if the
> issue is already known, in which case I would be grateful for any further
> hints regarding a remedy.
> Regards
> Wolfgang
Looks to be related, by magnitude, mostly to the work going on for this
pull request:
https://github.com/POV-Ray/povray/pull/358
and two or three similar open github issues - most/all? mentioned in the
358 discussion thread as I recall.
In your case the first ray surface intersection is being ignored if it
is closer than 1e-4. FYI. I'm adding your scene to my solver/tolerance
testing scene collection.
The current - and near term - work around in your scene is to keep the
camera more than 1e-4 off/outside the red plane's surface.
A better rule of thumb though is >1e-3 outside shapes / away from
surfaces for lights, cameras and surface relationships - in the world
scene space. In some scenes with the orthographic camera & user_defined
cameras that might not be possible depending upon the scene. It's not
enough for some shapes and scene set ups, but still a decent rule of
thumb value.
My current, local, solver branch going after a set of related fixes
renders only the red plane for what it's worth. That branch is an effort
aimed at fixing/improving a largish set of accuracy issues to which this
one (pull 358 et al) is somewhat related.
Bill P.
