POV-Ray : Newsgroups : povray.bugreports : CLipka: Possible BUG Found!!! :-) : Re: CLipka: Possible BUG Found!!! :-) Server Time
20 Mar 2026 23:36:54 EDT (-0400)
Date: 12 Feb 2016 14:41:47
Message: <56be357b$1@news.povray.org>
Am 12.02.2016 um 10:35 schrieb Sven Littkowski:
> and once again I gladly report a possible BUG! At least, it seems to be
> a bug, let's see.
Guess what: Again it isn't :P
> But using now a heightfield, I get an error message.
> object
>  HF_Cylinder( Fn_1, // Function,
>                  0, // UseUVheight:  0 or 1
>                  1, // UseUVtexture: 0 or 1
>            <50,50>, // Resolution,
>                  1, // Smooth: 0 or 1
>  "Colony Ship I - Heightfield Landscape.png", // FileName, ""=no file,
>            <0,0,0>, // EndA,
>          <0,1.5,0>, // EndB
>               1.60 ,// Radius
>                0.05  // Depth
>  scale < 0.58, 0.67, 0.58 >  // error here when using a heightfield
>  rotate < 90.0, 0.0, 0.0 >
>  scale < 1500.0, 1500.0, 2500.0 >
You've misunderstood the FileName parameter.
From the documentation:
There are several HF macros in shapes.inc, which generate meshes in
various shapes. All the HF macros have these things in common:
* The HF macros do NOT DIRECTLY USE AN IMAGE for input, but evaluate a
user-defined function. The macros deform the surface based on the
function values.
* The macros can either WRITE TO A FILE to be included later, or create
an object directly. If you want to output to a file, simply specify a
filename. If you want to create an object directly, specify "" as the
file name (an empty string).
Specifying a FileName would be useful in animations, or if your
(pseudo-) height field is so large that you don't want it to be
re-computed each time you render the scene, e.g.:
    #declare RecomputeHFCylinder = (clock = 0);
    #if (RecomputeHFCylinder)
      HF_Cylinder( ..., "Foo.inc", ...)
    object {
      #include "Foo.inc"
      scale ...
Note that when used in this mode, the HF_Cylinder(...) macro does not
evaluate to an object, but simply generates the specified file as a side
effect, so your code
    object {
      HF_Cylinder( ..., "Heightfield Landscape.png", ...)
      scale ...
will evaluate to
    object {
      scale ...
while at the same time overwriting(!) the file "Heightfield
Landscape.png" with plain text reading:
    mesh2 {...}
To generate a HF_Cylinder from an image, you'd need to use a pigment
function.
> PITA nomination?   :-)
Absolutely ;)
