POV-Ray : Newsgroups : povray.bugreports : Blobs: Error 1: Negative Values: Holes! / Error 2: Alpha Value Overwriting? : Re: Blobs: Error 1: Negative Values: Holes! /Error2:AlphaValueOverwriting? Server Time
21 Mar 2026 07:12:33 EDT (-0400)
Date: 23 Dec 2015 10:29:08
Message: <567abdc4$1@news.povray.org>
On 12/23/2015 09:53 AM, clipka wrote:
> Am 23.12.2015 um 08:00 schrieb Sven Littkowski:
>> This test code still shows the following errors (I just tested):
>> - non-textured or hollow ring-shape border errors (negative values)
> Here's the news: It /is/ related to numerical precision, though
> unfortunately not in the portion that is affected by the "sturm"
> keyword. If you scale the whole scene down by a factor of 0.01, those
> artifacts disappear entirely.
> Also, POV-Ray 3.6 shows the same behaviour, so this is not a simple case
> of just figuring out what was accidently changed and amending the new
> code accordingly. Instead, it would require someone with a knack for
> numerical precision issues to look really closely at the code for a
> while, figure out where exactly stuff breaks, and come up with some
> smart way of avoiding the issue.
> Until then, I would recommend keeping blob sizes in the single-digit
> range (after scaling).
>> - boxish texture problems in cupola shadow areas on cupolas
>> - no dark shadow on lower blob areas (the gray hull has them)
> See my other posts.
Christoph,
For what it is worth, I was following the same numerical accuracy trail.
Leaving things at Sven's current scale ad changing the following in
blob.cpp from
/* Minimal intersection depth for a valid intersection. */
const DBL DEPTH_TOLERANCE = 1.0e-2;
to
const DBL DEPTH_TOLERANCE = 1.0e-3;
was enough to clean up the solution.
I am not an expert at numerical algorithms but I look at these two
settings in blob.cpp and I wonder if the values are not perhaps set for
the old single precision days?
const DBL DEPTH_TOLERANCE = 1.0e-6;      // previous value 1.0e-2
/* Tolerance for inside test. */
const DBL INSIDE_TOLERANCE = 1.0e-12;    // previous value 1.0e-6
I'd think values such as those updated above not unreasonable these
days. The above runs OK on the few blobs I have. I don't understand
enough of the algorithm to know if there are other implications for
moving to much tighter tolerances.
Aside: AA was tending to hide the numerical artifacts which happen in
quite a few places other than the most obvious in Sven's example.
Thinking we have perhaps we've been living with some of these accuracy
issues for a while with AA often cleaning things up to where we don't
notice?
Bill P.
