POV-Ray : Newsgroups : povray.bugreports : Blobs: Error 1: Negative Values: Holes! / Error 2: Alpha Value Overwriting? : Re: Blobs: Error 1: Negative Values: Holes! / Error 2:AlphaValueOverwriting? Server Time
16 Mar 2026 03:27:19 EDT (-0400)
Date: 23 Dec 2015 02:00:33
Message: <567a4691@news.povray.org>
Before I am making changes and additions to the scene files, I use
always a test file where I am developing each feature. I am giving you
now the code of that test file, it reproduces these non-textured or
black edges though I am using a plain red pigment instead of the real
textures (with large texture image files).
If you afterwards want, I will also give you my texture file and the
texture images (though they are very large). But try first with this
test file as it reproduces the error.
Meanwhile, I will try the STURM feature...
PS: not the shape of the round cupolas become boxish, but their textures
on the edges. Even in this relatively plain test file code, if you look
into their shadow areas, you will see this again. I used a resolution of
8,000x4,500, AA 0.3. I was wrong with typing ALPHA, I meant to type
AMBIENT and EMISSION.
This test code still shows the following errors (I just tested):
- non-textured or hollow ring-shape border errors (negative values)
- boxish texture problems in cupola shadow areas on cupolas
- no dark shadow on lower blob areas (the gray hull has them)
For showing of the hull windows problem, I will develop a second file.
#version 3.7;
#declare MyRadiosity = on;
global_settings
 #if(MyRadiosity)
  radiosity
   media on
   pretrace_start 0.08
   pretrace_end   0.015
   count 400
   error_bound 0.75
   recursion_limit 1
 subsurface        {}
 adc_bailout       0.0039
 ambient_light     rgb < 1.000, 1.000, 1.000 >
 assumed_gamma     1.000
 irid_wavelength   rgb < 0.250, 0.180, 0.140 >
 max_trace_level   5
 number_of_waves   10
 noise_generator   3
 charset           ascii
#declare LightDiameter =     10000.0;
#declare LightDistanceX =  -500000.0; // X = Left - Right
#declare LightDistanceY =  1000000.0; // Y = Up - Down
#declare LightDistanceZ =  -100000.0; // Z = Front - Back
#declare LightRotate =          36.0;
#declare MyLight =             0.125;
camera
 location < -200.0, 200.0, -200.0 >
 location < 0.0, 0.0, 50.0 >
 location < -5.0, 5.0, -5.0 >
 location < -850.0, 850.0, -850.0 >
 look_at < 0.0, 0.0, -50.0 >
 look_at < 0.0, 0.0, 0.0 >
 right 1.77*x
#declare MyLight = light_source { < LightDiameter, 0.0, 0.0 >  rgb <
0.98039, 0.94902, 0.89804 > * MyLight }
#declare MySun = union
#declare Count=0;
#while (Count < 360)
 object { MyLight  rotate < 0.0, Count, 0.0 > }
 #declare Count=Count+LightRotate;
object { MySun translate < LightDistanceX, LightDistanceY,
LightDistanceZ > }
// --- TEXTURES
 #declare HullFinish = finish
 brilliance   0.25
 phong albedo 0.05
 metallic     1.00
 ambient      0.00
 emission     0.00
#declare AntennaRed = texture
 pigment   //  Brick Red
  rgb < 0.74902, 0.34118, 0.22353 > /4
 finish { HullFinish }
 translate -0.5*(x+y)
 rotate < 0.0, 90.0, 0.0 >
 rotate < 90.0, 0.0, 0.0 >
 scale 2500.0
 translate < 0.0, 0.0, 100.0 >
#declare HullGentleRed = texture
 pigment   //  Rose Red
  rgb < 0.57, 0.31, 0.30 >
 scale 2500.0
#declare HullGray25 = texture
 pigment   //  Gray 50%
  rgb < 0.25, 0.25, 0.25 >
 scale 2500.0
#declare HullGray50 = texture
 pigment   //  Gray 50%
  rgb < 0.50, 0.50, 0.50 >
 scale 2500.0
#declare HullGray75 = texture
 pigment   //  Gray 50%
  rgb < 0.75, 0.75, 0.75 >
 scale 2500.0
#declare HullGray95 = texture
 pigment   //  Gray 50%
  rgb < 0.95, 0.95, 0.95 >
 scale 2500.0
#declare LightsRed1 = texture // Unten
 pigment { rgb < 0.74902, 0.34118, 0.22353 > /4 }
 finish
  ambient        4.0
  brilliance     0.25
  phong albedo   1.15
  phong_size     1.0
  metallic       1.00
  diffuse albedo 0.5
  emission rgb < 0.74902, 0.34118, 0.22353 > *3.0
#declare LightsRed2 = texture // Oben
 pigment { rgb < 0.74902, 0.34118, 0.22353 >  }
 finish
//  ambient        4.0
  brilliance     0.25
  phong albedo   1.15
  phong_size     1.0
  metallic       1.00
  diffuse albedo 0.5
  emission rgb < 0.74902, 0.2600, 0.22353 > *4.0
#declare LightsRed = texture
 finish
  brilliance     0.25
  phong albedo   1.15
  phong_size     1.0
  metallic       1.00
  diffuse albedo 0.5
#declare MyAntennaLights = texture { LightsRed }
// --- ITEMS
#declare TextureHullWindowsSide        = texture { AntennaRed }
#declare TextureHullRing               = texture { AntennaRed }
#declare TextureInteriorSide           = texture { AntennaRed }
#declare TextureDeepSide               = texture { AntennaRed }
#declare TextureHullCupolaPaintingSide = texture { AntennaRed }
#declare TextureDeepWindowsSide        = texture { AntennaRed }
#declare TextureHullSide               = texture { AntennaRed }
#declare TextureHullSphere             = texture { AntennaRed }
#declare TextureHullTop                = texture { AntennaRed }
#declare TextureInteriorWindowsSide    = texture { AntennaRed }
#declare TextureHullFront              = texture { AntennaRed }
#declare TextureInteriorSphere         = texture { AntennaRed }
#macro
HullCommandFrontCutout(MyAmount,MySize,MyWidth,MyBegin,MyHeightRange,MySeed,MyTexture)
union
 #declare MyY=seed(1*MySeed);
 #declare MyZ=seed(2*MySeed);
 #declare MyHeight=seed(3*MySeed);
 #declare MyCount=1;
 #while (MyCount<=MyAmount)
  #declare MyBoxY=rand(MyY);
  #declare MyBoxZ=rand(MyZ);
  #declare MyBoxHeight=rand(MyHeight);
  box
   < -MyWidth, (-MySize*MyBoxY), -1000.0 > < MyWidth, (MySize*MyBoxY),
((-MyBegin)-(50.0*MyBoxZ)) >
   translate < 0.0, -(MyHeightRange*MyBoxHeight), 0.0 >
  box
   translate < 0.0, (MyHeightRange*MyBoxHeight), 0.0 >
  #declare MyCount=MyCount+1;
 texture { MyTexture }
#declare HullCommandWhole = union
 cylinder // schmaler Außenring
  < -12.5, 0.0, 0.0 > < 12.5, 0.20, 0.0 > 500.0
  texture { TextureHullRing }
 cylinder // dicker Innenzylinder
  < -62.5, 0.0, 0.0 > < 62.5, 0.0, 0.0 > 450.0
  texture { TextureHullWindowsSide }
 difference
  sphere // Verdickung
   < 0.0, 0.0, 0.0 > 475.0
   scale < 0.215, 1.0, 1.0 >
  difference
   sphere // Verdickung-Aushöhlung
    scale 0.975
   cylinder // nicht aushöhlen um WH-Generator herum
    < -100.0, 0.0, -250.0 > < 100.0, 0.0, -250.0 > 115.0
   texture { TextureInteriorSide }
  HullCommandFrontCutout(55,25.0,99.999,265.0,300.0,15,TextureDeepSide)
// Einschnitte vorne
  cylinder
   < -100.0, 0.0, -250.0 > < 100.0, 0.0, -250.0 > 90.0
   texture { TextureDeepSide }
  cylinder
   < -62.5, 0.0, 0.0 > < 62.5, 0.0, 0.0 > 475.0
 torus // von Vorne: links
  450.0, 50.0
  rotate < 0.0, 0.0, 90.0 >
  translate < -12.5, 0.0, 0.0 >
 torus // von Vorne: rechts
  450.0, 50.0
  translate < 12.5, 0.0, 0.0 >
 sphere // ganz vorne
  < 0.0, 0.0, 0.0 > 60.0
  scale < 0.3, 1.0, 1.0 >
  translate < -60.0, 250.0, -230.0 >
  texture { TextureHullCupolaPaintingSide translate < 0.0, 0.0, -100.0 > }
  translate < 60.0, 250.0, -230.0 >
  translate < -60.0, -250.0, -230.0 >
  translate < 60.0, -250.0, -230.0 >
 sphere // #2
  < 0.0, 0.0, 0.0 > 40.0
  scale < 0.25, 1.0, 1.0 >
  translate < -60.0, 310.0, -160.0 >
 sphere // #2
  translate < 60.0, 310.0, -160.0 >
 sphere // #2
  translate < -60.0, -310.0, -160.0 >
 sphere // #2
  translate < 60.0, -310.0, -160.0 >
 sphere // #3 Rounder
  < 0.0, 0.0, 0.0 > 50.0
  scale < 0.6, 1.0, 1.0 >
  translate < -50.0, 380.0, -70.0 >
  translate < 50.0, 380.0, -70.0 >
  translate < -50.0, -380.0, -70.0 >
  translate < 50.0, -380.0, -70.0 >
 sphere // #4 Deeper Rounder
  < 0.0, 0.0, 0.0 > 70.0
  scale < 0.4, 1.0, 1.0 >
  translate < -70.0, 280.0, 120.0 >
  translate < 70.0, 280.0, 120.0 >
  translate < -70.0, -280.0, 120.0 >
  translate < 70.0, -280.0, 120.0 >
 sphere // #5 Inner Rounder
  < 0.0, 0.0, 0.0 > 80.0
  translate < -90.0, 180.0, 30.0 >
  translate < 90.0, 180.0, 30.0 >
  translate < -90.0, -180.0, 30.0 >
  translate < 90.0, -180.0, 30.0 >
 sphere // #6 Side Top
  < 0.0, 0.0, 0.0 > 90.0
  scale < 1.0, 1.0, 1.0 >
  translate < -160.0, 110.0, 350.0 >
  texture { TextureHullSide }
  translate < 160.0, 110.0, 350.0 >
  translate < -160.0, -110.0, 350.0 >
  translate < 160.0, -110.0, 350.0 >
 sphere // #7 Side Hangar Medium Top
  translate < -390.0, 120.0, 360.0 >
  translate < 390.0, 120.0, 360.0 >
  translate < -390.0, -120.0, 360.0 >
  translate < 390.0, -120.0, 360.0 >
 sphere // #7 Side Hangar Small Top
  translate < -500.0, 130.0, 310.0 >
  translate < 500.0, 130.0, 310.0 >
  translate < -500.0, -130.0, 310.0 >
  translate < 500.0, -130.0, 310.0 >
 box // dunklere Front
  < -62.501, -200.0, -300.0 > < -62.5, 200.0, -100.0 >
  texture { TextureDeepWindowsSide }
  < 62.5, -200.0, -300.0 > < 62.015, 200.0, -100.0 >
 cylinder // Wormhole Generator Rounding
  < 0.0, -110.0, 0.0 > < 0.0, 110.0, 0.0 > 62.5
  scale < 1.0, 1.0, 2.0 >
  translate < 0.0, 0.0, -140.0 >
#declare HullCommandShape = union
  450.0, 50.0
  450.0, 50.0
#declare HullCommandOuterShell = difference
 object { HullCommandWhole texture { TextureHullSide } }
 object { HullCommandShape scale < 0.975, 0.9975, 0.99 > texture {
TextureInteriorSide } } // den Rumpf hohl machen ...
 box { < -100.0, -300.0, -600.0> < 100.0, 300.0, -300.0 > texture {
TextureHullFront } } // frontale hohe Öffnung für Antennen
 box { < -37.5, -600.0, -600.0> < 37.5, 600.0, -275.0 > texture {
TextureHullFront } }   // schmalere frontale hohe Öffnung für Antennen
 cylinder
  < -100.0, 300.0, -500.0 > < 100.0, 300.0, -500.0 > 200.0  // obere und
untere Abrundungen für frontale hohe Öffnung für Antennen
  texture { TextureHullFront }
 cylinder
  < -100.0, -300.0, -500.0 > < 100.0, -300.0, -500.0 > 200.0  // obere
und untere Abrundungen für frontale hohe Öffnung für Antennen
 box // keine Rumpfschnitte vorne wo Verdickung
  < -100.0, -200.0, -500.0 > < 100.0, 200.0, -300.0 >  // Wormhole
Generator Gegend
#declare HullCommandInnerShell = difference // innere Doppelwand
 object { HullCommandShape scale 0.90 texture { TextureInteriorSide } }
 object { HullCommandShape scale < 0.880, 0.898, 0.898 > texture {
 box { < -100.0, -600.0, -600.0> < 100.0, 600.0, -280.0 > texture {
TextureHullFront } } // Front-Einschnitt
 scale < 1.0, 1.075, 1.05 >
#declare MyCommandBlob = difference  // Querrumpf
 blob
  threshold 0.75
  cylinder { <  -125.0,    0.0,   50.0 > <  125.0,    0.0,   50.0 >
2500.0, 0.7 texture { TextureHullWindowsSide } }
  cylinder { <  -125.0,    0.0,  100.0 > <  125.0,    0.0,  100.0 >
600.0, 0.2 texture { TextureHullTop } } // Querrumpf
 difference
  cylinder { < -150.0, 0.0,  200.0 > <  150.0, 0.0,  200.0 > 370.0
  cylinder { < -150.1, 0.0, -250.0 > <  150.1, 0.0, -250.0 > 110.0
#declare MyMidshipBlob = blob
 #declare MyWidth     = 1.75;
 #declare MyThickness = 0.01;
 #declare MyZ         = 0.20;
 threshold 0.5
 cylinder { < -0.2, 0.0, 0.0 > < 0.2, 0.0, 0.0 > 2.0, 1 scale < 0.12,
1.00, 1.0 > translate < 0.0, 0.0, -0.50 > }
 cylinder { < -0.2, 0.0, 0.5 > < 0.2, 0.0, 0.5 > 0.75, 1 scale < 0.5,
 cylinder { < -0.2, 0.0, 0.0 > < 0.2, 0.0, 0.0 > 2.0, 1 scale < 0.10,
0.50, 0.5 > translate < 0.0, 0.0, -0.25 > }
 cylinder { < -MyWidth,  MyThickness+0.150,   MyZ+0.00 > < MyWidth,
MyThickness+0.150,   MyZ+0.00 > 0.25, 1 }
 cylinder { < -MyWidth,  MyThickness/2+0.120, MyZ+0.00 > < MyWidth,
MyThickness/2+0.120, MyZ+0.00 > 0.25, 1 }
 cylinder { < -MyWidth,  MyThickness/2+0.090, MyZ+0.00 > < MyWidth,
MyThickness/2+0.090, MyZ+0.00 > 0.25, 1 }
 cylinder { < -MyWidth,  MyThickness/2+0.060, MyZ+0.00 > < MyWidth,
MyThickness/2+0.060, MyZ+0.00 > 0.25, 1 }
 cylinder { < -MyWidth,  MyThickness/2+0.030, MyZ+0.00 > < MyWidth,
MyThickness/2+0.030, MyZ+0.00 > 0.25, 1 }
 cylinder { < -MyWidth,  0.00,                MyZ+0.00 > < MyWidth,
0.00,                MyZ+0.00 > 0.25, 1 }
 cylinder { < -MyWidth, -MyThickness/2-0.030, MyZ+0.00 > < MyWidth,
-MyThickness/2-0.030, MyZ+0.00 > 0.25, 1 }
 cylinder { < -MyWidth, -MyThickness/2-0.060, MyZ+0.00 > < MyWidth,
-MyThickness/2-0.060, MyZ+0.00 > 0.25, 1 }
 cylinder { < -MyWidth, -MyThickness/2-0.090, MyZ+0.00 > < MyWidth,
-MyThickness/2-0.090, MyZ+0.00 > 0.25, 1 }
 cylinder { < -MyWidth, -MyThickness/2-0.120, MyZ+0.00 > < MyWidth,
-MyThickness/2-0.120, MyZ+0.00 > 0.25, 1 }
 cylinder { < -MyWidth, -MyThickness-0.150,   MyZ+0.00 > < MyWidth,
-MyThickness-0.150,   MyZ+0.00 > 0.25, 1 }
 cylinder { < -MyWidth,  MyThickness+0.150,   MyZ+0.825 > < MyWidth,
MyThickness+0.150,   MyZ+0.075 > 0.25, 1 }
 cylinder { < -MyWidth, -MyThickness-0.150,   MyZ+0.825 > < MyWidth,
-MyThickness-0.150,   MyZ+0.075 > 0.25, 1 }
 cylinder { < -MyWidth,  MyThickness  , MyZ+0.15 > < MyWidth,
MyThickness  , MyZ+0.15 > 0.5, 1 }
 cylinder { < -MyWidth, -MyThickness  , MyZ+0.15 > < MyWidth,
-MyThickness  , MyZ+0.15 > 0.5, 1 }
 cylinder { < -MyWidth,  MyThickness  , MyZ+0.30 > < MyWidth,
MyThickness  , MyZ+0.30 > 0.5, 1 }
 cylinder { < -MyWidth, -MyThickness  , MyZ+0.30 > < MyWidth,
-MyThickness  , MyZ+0.30 > 0.5, 1 }
 cylinder { < -MyWidth,  MyThickness  , MyZ+0.45 > < MyWidth,
MyThickness  , MyZ+0.45 > 0.5, 1 }
 cylinder { < -MyWidth, -MyThickness  , MyZ+0.45 > < MyWidth,
-MyThickness  , MyZ+0.45 > 0.5, 1 }
 cylinder { < -MyWidth,  MyThickness  , MyZ+0.60 > < MyWidth,
MyThickness  , MyZ+0.60 > 0.5, 1 }
 cylinder { < -MyWidth, -MyThickness  , MyZ+0.60 > < MyWidth,
-MyThickness  , MyZ+0.60 > 0.5, 1 }
 cylinder { < -MyWidth,  MyThickness  , MyZ+0.75 > < MyWidth,
MyThickness  , MyZ+0.75 > 0.5, 1 }
 cylinder { < -MyWidth, -MyThickness  , MyZ+0.75 > < MyWidth,
-MyThickness  , MyZ+0.75 > 0.5, 1 }
MyThickness+0.150,   MyZ+0.825 > 0.25, 1 }
-MyThickness-0.150,   MyZ+0.825 > 0.25, 1 }
 cylinder { < -MyWidth,  MyThickness+0.150,   MyZ+0.90 > < MyWidth,
MyThickness+0.150,   MyZ+0.90 > 0.25, 1 }
 cylinder { < -MyWidth,  MyThickness/2+0.120, MyZ+0.90 > < MyWidth,
MyThickness/2+0.120, MyZ+0.90 > 0.25, 1 }
 cylinder { < -MyWidth,  MyThickness/2+0.090, MyZ+0.90 > < MyWidth,
MyThickness/2+0.090, MyZ+0.90 > 0.25, 1 }
 cylinder { < -MyWidth,  MyThickness/2+0.060, MyZ+0.90 > < MyWidth,
MyThickness/2+0.060, MyZ+0.90 > 0.25, 1 }
 cylinder { < -MyWidth,  MyThickness/2+0.030, MyZ+0.90 > < MyWidth,
MyThickness/2+0.030, MyZ+0.90 > 0.25, 1 }
 cylinder { < -MyWidth,  0.00,                MyZ+0.90 > < MyWidth,
0.00,                MyZ+0.90 > 0.25, 1 }
 cylinder { < -MyWidth, -MyThickness/2-0.030, MyZ+0.90 > < MyWidth,
-MyThickness/2-0.030, MyZ+0.90 > 0.25, 1 }
 cylinder { < -MyWidth, -MyThickness/2-0.060, MyZ+0.90 > < MyWidth,
-MyThickness/2-0.060, MyZ+0.90 > 0.25, 1 }
 cylinder { < -MyWidth, -MyThickness/2-0.090, MyZ+0.90 > < MyWidth,
-MyThickness/2-0.090, MyZ+0.90 > 0.25, 1 }
 cylinder { < -MyWidth, -MyThickness/2-0.120, MyZ+0.90 > < MyWidth,
-MyThickness/2-0.120, MyZ+0.90 > 0.25, 1 }
 cylinder { < -MyWidth, -MyThickness-0.150,   MyZ+0.90 > < MyWidth,
-MyThickness-0.150,   MyZ+0.90 > 0.25, 1 }
 sphere { < 0.0, 0.0, 0.0 > 0.5, 1 scale < 1.00, 1.00, 0.5 > translate <
 MyWidth-0.2, 0.0, MyZ-0.25 > }
-MyWidth+0.2, 0.0, MyZ-0.25 > }
 sphere { < 0.0, 0.0, 0.0 > 0.5, 1 scale < 1.25, 1.75, 2.5 > translate <
 MyWidth-0.3, 0.0, MyZ+0.9 > }
-MyWidth+0.3, 0.0, MyZ+0.9 > }
 sphere { < 0.0, 0.0, 1.5 > 0.5, -4 } // Heckeinschnitt
 sphere { <  0.35,  0.25, MyZ+0.08 > 0.275, -1.5 }
 sphere { <  0.35, -0.25, MyZ+0.08 > 0.275, -1.5 }
 sphere { < -0.35,  0.25, MyZ+0.08 > 0.275, -1.5 }
 sphere { < -0.35, -0.25, MyZ+0.08 > 0.275, -1.5 }
 sphere { <  0.85,  0.25, MyZ+0.06 > 0.225, -1.75 }
 sphere { <  0.85, -0.25, MyZ+0.06 > 0.225, -1.75 }
 sphere { < -0.85,  0.25, MyZ+0.06 > 0.225, -1.75 }
 sphere { < -0.85, -0.25, MyZ+0.06 > 0.225, -1.75 }
 sphere { <  1.10,  0.23, MyZ-0.04 > 0.175, -1.50 }
 sphere { <  1.10, -0.23, MyZ-0.04 > 0.175, -1.50 }
 sphere { < -1.10,  0.23, MyZ-0.04 > 0.175, -1.50 }
 sphere { < -1.10, -0.23, MyZ-0.04 > 0.175, -1.50 }
 scale 450.0
 translate < 0.0, 0.0, 250.0 >
//cylinder { < -62.5, 0.0, 0.0 > < 62.5, 0.0, 0.0 > 500.0 pigment { rgbf
< 1.0, 0.0, 0.0, 0.5 > } }
#declare MidshipHull = difference
 union
  sphere { < 0.0, 0.0,  0.0 > 250.0 texture { TextureHullSphere }
translate < -500, 0.0, 550.0 > }
translate <  500, 0.0, 550.0 > }
//  sphere { <  000.0, 0.0,  900.0 > 400.0 scale < 1.0, 0.60, 1.0 >
texture { TextureHullTop } } // Mining Port
  object { MyCommandBlob } // Kommandorumpf
  object { MyMidshipBlob } // Mittschiffsrumpf
 object { HullCommandShape scale 0.99 texture {
TextureInteriorWindowsSide } }
 box { < -100.0, -600.0, -600.0> < 100.0, 600.0, -300.0 > texture {
 cylinder { < -1050.0, 0.0, 3000.0 > < -1050.0, 0.0, -1000.0 >  500.0
texture { TextureHullSide } } // Hangar
 cylinder { <  1050.0, 0.0, 3000.0 > <  1050.0, 0.0, -1000.0 >  500.0
 sphere { < 0.0, 0.0,  0.0 > 240.0 texture { TextureInteriorSphere }
translate < -500, 0.0, 550.0 > } // Side Cupola
translate <  500, 0.0, 550.0 > } // Side Cupola
object { HullCommandOuterShell }
object { HullCommandInnerShell }
object { MidshipHull }
