POV-Ray : Newsgroups : povray.bugreports : Keep Single Instance not always working : Re: Keep Single Instance not always working Server Time
21 Oct 2026 17:22:51 EDT (-0400)
Date: 22 Sep 2015 20:08:00
Message: <5601ed60$1@news.povray.org>
On 9/22/2015 2:05 PM, Christian Froeschlin wrote:
> On 22.09.2015 6:32, Mike Horvath wrote:
>> You are correct! How do I fix it?
>> Windows 7 Pro x64
> You can use Control Panel > Default Programs to associate file
> types with pvengine64.exe. Also make sure all your desktop and
> start menu shortcuts point to that version (or if you don't know
> exactly what the problem is you could also rename pvengine.exe
> to pvengine-hidden.exe to prevent accidental usage).
> Note if you actually have multiple versions installed, Windows is
> notoriously bad at changing file associations betweens *.exe's with
> the same name.
That worked, thanks!
