POV-Ray : Newsgroups : povray.bugreports : Keep Single Instance not always working : Re: Keep Single Instance not always working Server Time
4 Jul 2026 10:37:15 EDT (-0400)
Date: 22 Sep 2015 14:05:31
Message: <5601986b$1@news.povray.org>
On 22.09.2015 6:32, Mike Horvath wrote:
> You are correct! How do I fix it?
> Windows 7 Pro x64
You can use Control Panel > Default Programs to associate file
types with pvengine64.exe. Also make sure all your desktop and
start menu shortcuts point to that version (or if you don't know
exactly what the problem is you could also rename pvengine.exe
to pvengine-hidden.exe to prevent accidental usage).
Note if you actually have multiple versions installed, Windows is
notoriously bad at changing file associations betweens *.exe's with
the same name.
