POV-Ray : Newsgroups : povray.bugreports : Possible JPEG file output in Povray 3.7 : Re: Possible JPEG file output in Povray 3.7 Server Time
7 Apr 2026 19:56:39 EDT (-0400)
Date: 25 Jan 2015 19:33:09
Message: <54c58b45$1@news.povray.org>
Am 25.01.2015 um 09:18 schrieb Ken Shumway:
> When I try to output in Jpeg format, I get this error message:  JPEG parameter
> stgruct mismatch: library thinks size is 372, caller expects 376 Render failed.
>   I am running with Ubuntu Linux 10.4. The screen output from Povray includes a
> statement that the support library LibJPEG 62 with a Copyright date of 2013 is
> used.  Is there a library that needs updating to fix this problem?
If you're using the Ubuntu pre-built povray package, please contact the
corresponding Ubuntu package maintainer for support; it should be their
job to make sure that the POV-Ray package contains all the relevant
dependency information to also install the matching libjpeg version.
If you're using POV-Ray compiled from source, theoretically all you'd
need to do is make sure that you have matching libjpeg and libjpeg-dev
packages installed when you configure and build POV-Ray. (Do NOT try to
use the libjpeg sources coming with the POV-Ray source; it's only
included to build POV-Ray for Windows.)
