POV-Ray : Newsgroups : povray.bugreports : Error with big *.inc file : Re: Error with big *.inc file Server Time
20 Mar 2026 19:22:39 EDT (-0400)
Date: 29 Aug 2014 14:17:05
Message: <5400c3a1$1@news.povray.org>
On 08/29/2014 01:24 PM, Alex wrote:
> "LanuHum" <Lan### [at] yandexru> wrote:
>> "Alex" <ale### [at] hotmailcom> wrote:
>>> I get the following error when using a big inc file:
>>> "C:\Temp\POV\Mesh_tracts_big.inc" line 64136462: Parse Error: No matching } in
>>> 'object', float function 'float constant' found instead.
>>> But there is nothing wrong with that file. Note that I do *not* get any error
>>> when I use smaller file.
>>> I have put the relevant files (Mesh_tracts_big.inc, Mesh_tracts_small.inc and
>>> Scene_def.pov) here (~1/2 GB zip file):
>>> http://www.isi.uu.nl/People/Alexander/files/POV.zip
>>> I am using Windows 7 Professional 64 bit OS (24 threads with 128 GB RAM). To
>>> render the big file, you need ~30 GB RAM. I used both the latest POV-Ray version
>>> and the previous one... no luck!
>>> Many thanks in advance for any help!
>>> Cheers,
>>> Alexander
>> I am using Linux Mageia-4 64 bit OS (i3 with 16 GB RAM).
>> No problem with Mesh_tracts_big.inc (3.1 GB)
>> Look here:
http://news.povray.org/povray.binaries.images/attachment/%3Cweb.5400a08ac27938b17a3e03fe0%40news.povray.org%3E/big_in
> c.
>> jpg
> Great - so this confirms that there is nothing wrong with the files ;-)! Unless
> someone can get it working on a Windows OS, this remains a bug, not?!
> Any suggestions on how to fix it - besides getting a Linux OS ;-)?
> Kind regards,
> Alexander
don't think it's exclusive to windows ... i'm linux user. didn't test
your specific case but i've seen this problem in the past, and
coincidentally just the other day with a large include that i've used in
the past (just two days ago) without difficulty. /nothing/ on my system
has changed. as a matter of fact had it happen /before/ 3.7 release but
kept my mouth shut ... well because and i won't get into that
