POV-Ray : Newsgroups : povray.binaries.utilities : Wood design program test version Server Time
7 Apr 2026 19:40:39 EDT (-0400)
  Wood design program test version (Message 31 to 39 of 39)
Subject: Re: Wood design program test version
Date: 8 Jul 2022 03:30:00
Message: <web.62c7da1c4b788a98e660d035aa81652d@news.povray.org>
> Almost error-free! :-)
> In output file: example1_bumps_pattern_detail.inc  there are still five
> instances of offensive comma's that need to be replaced by dots. I show
> them here below with an arrow:
> //----start code----
> #include "bumps_detail_pattern_macros.inc"
> #declare f_height_for_bumps_extent =
> generate_bump_follow_height_trend_f(20.0);
> // ------------ fiber ------------
> #declare f_thin_fiber_mockup0 =
> generate_thin_circled_pattern_f_input_t_theta_h(
> 10.0, 60.0, 3.0, 3.0, 0.015, 5,
> 0.007, 0,32,                      <=== 0,32 should be 0.32
> 0.00, 2.50, 0.14, 0.15,
> seed(44),
> 0.014, 20.00
> #declare f_thin_fiber_mockup1 =
> 10.0, 60.0, 3.0, 3.0, 0.017, 4,
> 0.011, 0,32,                      <=== 0,32 should be 0.32
> seed(45),
> 0.014, 20.00
> #declare f_thin_fiber =
> function(x, y, z, time_value) {
> +0,50*f_thin_fiber_mockup0(           <=== 0,50 should be 0.50
>      time_value,
>      f_theta(x,y),
>      f_height_for_bumps_extent(x, y, z)
> +0,50*f_thin_fiber_mockup1(           <=== 0,50 should be 0.50
>      time_value,
>      f_theta(x,y),
> // ------------- large color ---------------------------
> #declare f_large_color_block_mockup =
> 10.0, 60.0, 3.0, 3.0, 2.32, 4,
> 0.144, 0,32,                      <=== 0,32 should be 0.32
> seed(25),
> 0.014, 20.00
> #declare f_large_color_block =
> f_adjust_sharp_distribution(
>      x, y, z,
>      f_large_color_block_mockup(
>          time_value,
>          f_theta(x,y),
> //----end code----
> With these corrected, the application works!
Yes, I correct it now..
I correct another problem for ...maybe non-windows system cannot output files
when click that "output" button. But need to be tried.
And I add an "exit" function in a menu.
Download 'wooddesignprogram alpha ver20220708.rar.dat' (967 KB)
Date: 8 Jul 2022 03:45:00
Message: <web.62c7df654b788a98e660d035aa81652d@news.povray.org>
> I guess that those numbers may change with the input by the user (I did
> not see that happen, though). You know best where those particular
> numbers come from.
I have not finished that scheme yet. In fact, the GUI for controlling the
detailed pattern doesn't start to be designed.
You can change that part (..._bumps_pattern_detail.inc) yourself. If my memory
serves me right, the functions produced here is prepare for the
"tree_colormap_temp_file.inc" only. I will try different combines, too.
> Next, I shall try to give my views/ideas on the layout, comprehensive
> use, etc, of the application.
> Thomas
Download 'wooddesignprogram alpha ver20220708.zip' (981 KB)
Date: 12 Jul 2022 07:35:00
Message: <web.62cd5afe4b788a981be3cd4b6cde94f1@news.povray.org>
hi,
(it is a day for "bugs", it seems :-))
tells me it works on MS Windows, but not (for me) on Linux (like 'rtr' </sigh>).
after exiting the program and changing into the 'example1' directory, POV-Ray
does not like the spaces in the file name, so when:
  $ povparse +i"show tree function.pov"
Problem with option setting
/usr/local/bin/povray-3.8.0-beta.2 +w32 +h32 -d -f -p -gr -gs +ishow tree
function.pov
Failed to parse command-line option
another error occurs because the 'pretrace_*' settings depend on image size, eg
with the (small) WxH settings above.
however, file renamed and using a large enough WxH, I get another error.  not
even sure what the problem is supposed to be (since the code looks kosher (to
the untutored eye)):
File 'functions.inc' line 9: Parse Warning: Scene language version changed after
 a 'default' statement. The changes in defaults normally associated with the
 language version change are not applied.
File 'example1_angular_shape_factor.inc' line 10: Possible Parse Error:
 Suspicious identifier found in function! If you want to call a function make
 sure the function you call has been declared. If you call an internal function,
 make sure you have included 'functions.inc'.
File 'example1_angular_shape_factor.inc' line 10: Parse Error: Expected
 'operator', ( found instead
Fatal error in parser: Cannot parse input.
Render failed
regards, jr.
Date: 13 Jul 2022 03:20:00
Message: <web.62ce71f44b788a989ac997d1aa81652d@news.povray.org>
"jr" <cre### [at] gmailcom> wrote:
> hi,
> function.pov
> Render failed
> regards, jr.
Thanks.
It should copy some text but it didn't.
(I should use \ not // for the file path connect)
I fix it and attach a new version.
No any other change, besides adding axis on the angular-shape-editor for
identify the direction.
Download 'wooddesignprogram alpha ver20220713.zip' (982 KB)
Date: 13 Jul 2022 04:35:00
Message: <web.62ce83224b788a981be3cd4b6cde94f1@news.povray.org>
hi,
works, thanks.  now need to find time to play.  cheers.
regards, jr.
Date: 14 Jul 2022 02:55:00
Message: <web.62cfbd8f4b788a989ac997d1aa81652d@news.povray.org>
> hi,
> regards, jr.
Glad to hear that works.
Date: 26 Sep 2022 12:55:00
Message: <web.6331d7d84b788a98d7b3739daa81652d@news.povray.org>
Hi, ...
I release a new test version here.
I freeze the curve diagram when the page uneditable.
And make an earlywood-latewood ratio editor.
I wrote many code to generate the pattern function..., instead of copy an entity
file. But looks not so different, just prepared for the future editor.
Download 'wooddesignprogram alpha ver20220926.rar.dat' (1104 KB)
Date: 26 Sep 2022 13:00:00
Message: <web.6331da624b788a98d7b3739daa81652d@news.povray.org>
..zip version
Download 'wooddesignprogram alpha ver20220926.zip' (1119 KB)
Date: 27 Dec 2022 11:40:00
Message: <web.63ab1f304b788a9895eb3bf9aa81652d@news.povray.org>
During these several months I'm practicing my *basic* programming ability(mostly
by a project I'm writing for another person), and interrupt this project.
I have learned something indeed like using "generics", "breakpoint debugger",
and
a bit more programming structure such as interface.
(Java part)
I will continue this wood design project in the future(at least two-three months
after). I want to refactor many of my components of it, too.
