POV-Ray : Newsgroups : povray.binaries.utilities : Domenator, last version Server Time
21 Apr 2025 16:45:56 EDT (-0400)
  Domenator, last version (Message 16 to 25 of 45)
Subject: Re: Domenator, last version
Date: 31 Aug 2021 02:15:06
Message: <612dc8ea@news.povray.org>
Op 30/08/2021 om 19:03 schreef Kenneth:
>> Interestingly: I copied the following dll's from the laptop where
>> Domenator /did/ work, to the one where it /didn't/, and Lo! it works
>> now! Go understand.
>> freeglut.dll (23-3-2018)
>> msvcp140d.dll (19-1-2018)
>> ucrtbased.dll (14-8-2016)
>> vcruntime140d.dll (23-3-2018)
>> Somehow, the more recent versions I downloaded a couple of days ago did
>> not do the job?!? [beyond my ken]
> Good to hear!
> I'd like to try the Domenator out as well, but I'm wary of installing .dlls
> (Windows 10). It's "beyond my Ken" too :=P
> Any tips you can give as to where they would go? Or problems to expect?
Hi Kenneth!
I am like you. The best you can do is to put them in the same folder as
the application itself. So, my Domenator folder contains:
Domenator.exe
freeglut.dll
msvcp140d.dll
ucrtbased.dll
vcruntime140d.dll
This works fine, except as I said earlier, with the most recent versions
of the dll's. I attach a zip with those which work for me as I am not
sure how or where you could find those particular versions. I copied
them from one of my other folders.
A tiny drawback of this method might be if you have several folders with
different applications and all containing copies of the same dll's. That
happens on my system. However, most dll's are quite small and take
little space, and I have not been aware of any interference. But more
knowledgeable people might know.
Download 'domenator_dlls.zip' (885 KB)
Date: 31 Aug 2021 02:35:23
Message: <612dcdab$1@news.povray.org>
Op 30/08/2021 om 18:45 schreef Mediat:
> Computer mysteries ;-))
Indeed.
> I'll post the next version in a few days
> Have fun and let me know
> Best regards
A couple of things I have forgotten since earlier versions:
1) how do you save to INC, STL, OBJ? clicking those buttons doesn't do
anything.
2) How do the different 'Material' options work?
Date: 31 Aug 2021 03:40:00
Message: <web.612ddbda3965e4e8d1712a2a5020ebe1@news.povray.org>
Hi Kenneth
I hope you'll succeed, Thomas has explained the problem and there is nothing I
can do.
Enjoy
Hi Thomas,
The STL and OBJ Button generate name.STL and name.OBJ files whiche you can read
in a lot of 3d-viewer (I use glc-viewer), and it should be compatible with 3D
printers (but I don't have access to any, so I haven't tried)
The INC button generates the POV file, these 3 files are generated in the
directory above the one where the exe stands (maybe not a very good idea)
If you don't declare any material, you will have to declare one in your pov-file
for the entire union, but you can be more specific :
1) Dome material is the same as the pov definition for the entire object
2) Face material will affect the mesh part only
3) Struts materials, you can define different material for parallel an meridian
struts, major and minor struts
4) Diagonal struts, same thing for the diagonals (usually you don't want to see
them, but I have an exemple ...)
5) Spheres material, usually the same as one of the struts tha the sphere
completes
In the image trashbin, the faces are not generated, only the major parallele
struts have a non 0 radius
In the franc-contois image (it is a dome I saw in a french xountryside called
lead material.
Download 'trashbin.jpg' (43 KB)
Preview of image 'trashbin.jpg'
Message: <web.612ddc523965e4e8d1712a2a5020ebe1@news.povray.org>
The other file
Download 'franc-comtois.jpg' (58 KB)
Preview of image 'franc-comtois.jpg'
Date: 31 Aug 2021 04:52:29
Message: <612dedcd$1@news.povray.org>
Op 31-8-2021 om 09:37 schreef Mediat:
> Hi Kenneth
> can do.
> Enjoy
> Hi Thomas,
Ah! OK. Confusing indeed, especially as the *.DOM file goes into the
same directory as the exe.
Also, saved *.DOM files when loaded again, do not show the originally
saved object, but a default half sphere.
I am confused about the 'Materials'(and the objects). Do I have to use
the same names as those given in the droplist for WireFrame/Flat Faces/
Smooth Faces? Whether I do that or not, no materials are exported, nor
is the geometry subdivided according to different materials. In Poseray,
I get one unnamed_group (a half sphere) with one unnamed_material
(white), whatever I do.
> completes
Hmmm... I am unable to reproduce this...
> lead material.
Nice ones!
Date: 31 Aug 2021 06:25:00
Message: <web.612e02f73965e4e8d1712a2a5020ebe1@news.povray.org>
Hi Thomas,
I'm not prood of this part, but I'm open to suggestion
I never experienced that, can you pack the DOM files in a Zip and I'll have a
look;
You can use any name, the material is not generated, just used, so you must
define the material used before the include
I noticed no problem, but I will create a "complete" sample
Best regards
Philippe
Date: 31 Aug 2021 07:20:00
Message: <web.612e0f4c3965e4e8d1712a2a5020ebe1@news.povray.org>
Hi Thomas,
Here is an image where I used all the 11 possible material and it seems to work
Best regards
Philippe
Download 'test_material.jpg' (66 KB)
Preview of image 'test_material.jpg'
Date: 1 Sep 2021 05:45:00
Message: <web.612f4b323965e4e84cef624e6e066e29@news.povray.org>
> Domenator.exe
> freeglut.dll
> msvcp140d.dll
> ucrtbased.dll
> vcruntime140d.dll
Thanks! And also for the .dll's. :-) I may give this a try and see what happens.
I have no idea yet if my Win 10 system has any of those dll's already installed
in other places (in which case, one version might be used rather than another?)
But such Windows voodoo is beyond my knowledge.
Date: 1 Sep 2021 06:00:00
Message: <web.612f4e653965e4e8d1712a2a5020ebe1@news.povray.org>
Hi Kenneth,
I hope it'll work and you'll enjoy it, if it is the case, feel free to report
any bug or request any feature
Best regards
Philippe
Date: 1 Sep 2021 08:04:00
Message: <612f6c30$1@news.povray.org>
Op 1-9-2021 om 11:43 schreef Kenneth:
>> Domenator.exe
>> freeglut.dll
>> msvcp140d.dll
>> ucrtbased.dll
>> vcruntime140d.dll
I have (I noticed) different versions of the same dll's in different
directories, the flotsam of several years of playing around :-) I never
experienced any trouble (which doesn't mean anything of course, given my
illiteracy into the arcane knowledge about our electronic little
helpers' hard/software).
