POV-Ray : Newsgroups : povray.binaries.utilities : Domenator, last version Server Time
5 Mar 2026 07:53:12 EST (-0500)
  Domenator, last version (Message 11 to 20 of 45)
Subject: Re: Domenator, last version
Date: 29 Aug 2021 02:35:58
Message: <612b2ace$1@news.povray.org>
Op 28/08/2021 om 17:13 schreef Mediat:
> Hi Thomas
> Isearch the net for error 0x000007b and here is what I found ;
> The 0x000007b error may be caused by windows system files damage. There can be
> many events which may have resulted in the system files errors.
> Go to Microsoft to download and install Visual C++ Redistributable Packages.
> I hope it'll work
> Best regards
> Philippe
OK. Got it to work on my second laptop, with the dll's of the earlier
version from 2018. I had lost track of it somehow. A bit confusing as
that was already version 4.0.
So, something not right indeed with my first laptop it seems. It works
fine otherwise, but I shall see what I can do.
Date: 29 Aug 2021 17:30:00
Message: <web.612bfb9e3965e4e8d1712a2a5020ebe1@news.povray.org>
Hi Thomas,
Glad it works.
If you're interested I'm preparing soome new features (for the fun)
Best regards
Date: 30 Aug 2021 10:42:02
Message: <612cee3a@news.povray.org>
Op 29-8-2021 om 23:26 schreef Mediat:
> Hi Thomas,
> Glad it works.
> Best regards
I am certainly interested.
Interestingly: I copied the following dll's from the laptop where
Domenator /did/ work, to the one where it /didn't/, and Lo! it works
now! Go understand.
freeglut.dll (23-3-2018)
msvcp140d.dll (19-1-2018)
ucrtbased.dll (14-8-2016)
vcruntime140d.dll (23-3-2018)
Somehow, the more recent versions I downloaded a couple of days ago did
not do the job?!? [beyond my ken]
Date: 30 Aug 2021 12:50:00
Message: <web.612d0b453965e4e8d1712a2a5020ebe1@news.povray.org>
Computer mysteries ;-))
I'll post the next version in a few days
Have fun and let me know
Best regards
Date: 30 Aug 2021 13:05:00
Message: <web.612d0f3b3965e4e84cef624e6e066e29@news.povray.org>
> now! Go understand.
Good to hear!
I'd like to try the Domenator out as well, but I'm wary of installing .dlls
(Windows 10). It's "beyond my Ken" too :=P
Any tips you can give as to where they would go? Or problems to expect?
Date: 31 Aug 2021 02:15:06
Message: <612dc8ea@news.povray.org>
Op 30/08/2021 om 19:03 schreef Kenneth:
>> now! Go understand.
> Good to hear!
Hi Kenneth!
I am like you. The best you can do is to put them in the same folder as
the application itself. So, my Domenator folder contains:
Domenator.exe
freeglut.dll
msvcp140d.dll
ucrtbased.dll
vcruntime140d.dll
This works fine, except as I said earlier, with the most recent versions
of the dll's. I attach a zip with those which work for me as I am not
sure how or where you could find those particular versions. I copied
them from one of my other folders.
A tiny drawback of this method might be if you have several folders with
different applications and all containing copies of the same dll's. That
happens on my system. However, most dll's are quite small and take
little space, and I have not been aware of any interference. But more
knowledgeable people might know.
Download 'domenator_dlls.zip' (885 KB)
Date: 31 Aug 2021 02:35:23
Message: <612dcdab$1@news.povray.org>
Op 30/08/2021 om 18:45 schreef Mediat:
Indeed.
> Best regards
A couple of things I have forgotten since earlier versions:
1) how do you save to INC, STL, OBJ? clicking those buttons doesn't do
anything.
2) How do the different 'Material' options work?
Date: 31 Aug 2021 03:40:00
Message: <web.612ddbda3965e4e8d1712a2a5020ebe1@news.povray.org>
Hi Kenneth
I hope you'll succeed, Thomas has explained the problem and there is nothing I
can do.
Enjoy
Hi Thomas,
The STL and OBJ Button generate name.STL and name.OBJ files whiche you can read
in a lot of 3d-viewer (I use glc-viewer), and it should be compatible with 3D
printers (but I don't have access to any, so I haven't tried)
The INC button generates the POV file, these 3 files are generated in the
directory above the one where the exe stands (maybe not a very good idea)
If you don't declare any material, you will have to declare one in your pov-file
for the entire union, but you can be more specific :
1) Dome material is the same as the pov definition for the entire object
2) Face material will affect the mesh part only
3) Struts materials, you can define different material for parallel an meridian
struts, major and minor struts
4) Diagonal struts, same thing for the diagonals (usually you don't want to see
them, but I have an exemple ...)
5) Spheres material, usually the same as one of the struts tha the sphere
completes
In the image trashbin, the faces are not generated, only the major parallele
struts have a non 0 radius
In the franc-contois image (it is a dome I saw in a french xountryside called
lead material.
Download 'trashbin.jpg' (43 KB)
Preview of image 'trashbin.jpg'
Message: <web.612ddc523965e4e8d1712a2a5020ebe1@news.povray.org>
The other file
Download 'franc-comtois.jpg' (58 KB)
Preview of image 'franc-comtois.jpg'
Date: 31 Aug 2021 04:52:29
Message: <612dedcd$1@news.povray.org>
Op 31-8-2021 om 09:37 schreef Mediat:
> Hi Kenneth
> can do.
> Enjoy
> Hi Thomas,
Ah! OK. Confusing indeed, especially as the *.DOM file goes into the
same directory as the exe.
Also, saved *.DOM files when loaded again, do not show the originally
saved object, but a default half sphere.
I am confused about the 'Materials'(and the objects). Do I have to use
the same names as those given in the droplist for WireFrame/Flat Faces/
Smooth Faces? Whether I do that or not, no materials are exported, nor
is the geometry subdivided according to different materials. In Poseray,
I get one unnamed_group (a half sphere) with one unnamed_material
(white), whatever I do.
> completes
Hmmm... I am unable to reproduce this...
> lead material.
Nice ones!
