POV-Ray : Newsgroups : povray.binaries.utilities : geode - 1 attachment Server Time
4 Sep 2025 03:02:41 EDT (-0400)
  geode - 1 attachment (Message 1 to 2 of 2)
Subject: geode - 1 attachment
Date: 18 Feb 2003 07:53:54
Message: <Xns93268DAC4A435fizbanlombardiacomit@204.213.191.226>
This couple of simple utility can be used to generate geodes with an
arbitrary number of points. geode.exe create a crane of sphere and
cylinders, while geode1.exe will generate a triangle mesh.
The source code (included) is heavily based on the work of V. Bulatov;
I've only modifiled the output (which was in VRML) to generate POV
files. I wasn't able to contact Mr Bulatov, but I think that his work can
be considered under public domain.
The code is compiled with borland free c++ compiler, tested on winnt and
should work on every win32 platform out there; the source is trivial to
compile for other platform (linux....).
For output samples, see p.b.i.
Download 'Geode.zip' (65 KB)
Subject: Re: geode - 1 attachment
Date: 19 Feb 2003 10:17:04
Message: <3e539ff0$1@news.povray.org>
"Zio Pera" <fiz### [at] lombardiacomit> wrote
<snip>
Confirmed. Both files compile under gcc with minimal addition
John
Run Fast
Run Free
Run Linux
