POV-Ray : Newsgroups : povray.binaries.utilities : Online files converter Server Time
28 Jul 2026 05:22:59 EDT (-0400)
  Online files converter (Message 81 to 90 of 106)
Subject: Re: Online files converter
Date: 8 Oct 2025 21:25:00
Message: <web.68e70ea3c90893361f9dae3025979125@news.povray.org>
yesbird wrote:
> Necessary precision is really dependent on a
> model's scale. Current release has 6 digits, let's try to test it. I
> guess, the file size is not a serious limitation, so increasing to 8-10
> is possible.
Just a cautionary observation.
It's difficult or impossible to predict the end user's use of a model or the
precision they need.
Is it possible to have the user select the desired precision before conversion?
Can a file size be estimated based on the number of vertices and the selected
precision?
Hard-coding magic numbers doesn't seem like the way to go if it isn't to
difficult to make everything adjustable.
- BW
Date: 8 Oct 2025 21:48:24
Message: <68e71468@news.povray.org>
Not sure that this is the most important thing to do now,
but could you give an examples of the modern systems with adjustable
precision and method they use to calculate it ?
I see that C4D gives 14 digits (attached).
YB
Download 'cube_c4d.obj.txt' (1 KB)
Date: 8 Oct 2025 22:20:00
Message: <web.68e71b55c90893361f9dae3025979125@news.povray.org>
(I wasn't making a value judgement about its importance or timeliness, I was
just making an observation.)
I guess various packages have "tolerance" and "decimation error" settings.
https://help.autodesk.com/view/PWRS/2025/ENU/?guid=GUID-465F277C-E3AE-4D83-B14E-0832137FCF4D
https://www.open3d.org/docs/latest/python_api/open3d.t.geometry.TriangleMesh.html
Simplify mesh by Threshold: This is an easy way to reduce the file size of a
mesh for manufacturing. This block will create the mesh with the least amount of
faces. A good starting point for the threshold is 1/4 to 1/8 of the
manufacturing tolerance.
Simplify mesh by Amount: This block generates a mesh that is smaller than the
original based on the specified amount. For example, a value of 0.9 will create
a mesh with 90% fewer faces, and as a result 90% smaller file size.
https://www.ntop.com/resources/blog/meshing-in-fea-cfd-manufacturing/
https://help.altair.com/inspire/en_us/topics/implicit/visualization_r.htm#:~:text=This%20is%20usually%20seen%20in,doing
%20this%20is%20shown%20below.
https://support.carveco.com/hc/en-gb/articles/19604059276316-3D-Design-Creating-Triangle-Mesh-For-Exporting#:~:text=The
%20two%20settings%20work%20hand,tolerance%20low%20and%20optimisation%20enabled.
https://nexus.hexagon.com/documentationcenter/en-US/bundle/VISI_2025_2_FLOW_Online_Help/page/Content/CadMeshTolerance.h
tml
Lots of search results for "triangle mesh decimation"
This would probably be the biggest file-size optimizer, because there's no
reason to have a cube with 10,000 coplanar triangle faces when 2 would
indistinguishably do the job - probably with more accuracy and fewer artifacts
to due to floating point noise.
How to calculate it?
Rounding and truncation, I would imagine.
Date: 8 Oct 2025 23:12:38
Message: <68e72826$1@news.povray.org>
On 09/10/2025 05:17, Bald Eagle wrote:
> yesbird wrote:
> I guess various packages have "tolerance" and "decimation error" settings...
Thank you for parsing Google search results, but I do not see a
concrete formula for precision calculation :).
Long things short: Paul Bourke after reviewing the first version of
converter was wondering why the precision of the data was changed
(increased) on conversion and suggested leaving it as it was in the
input file. I guess this makes sense, because we don't recalculate
coordinates, but simply repack them from one format to another.
In the next release I will follow his advice.
YB
Date: 9 Oct 2025 03:10:00
Message: <web.68e75efbc90893369ffda23b6830a892@news.povray.org>
Your materials are even improving, and already looked very good !
Please I insist, that it's a bad strategy to despise phones because as far as I
know, POV is still as of today the only 3D renderer working on Android through
its Termux port. (and no it does not overheat!)
and instead of Tik Tok the youths could have something so much better to do with
them ;-)
Date: 9 Oct 2025 03:32:46
Message: <68e7651e@news.povray.org>
On 08/10/2025 23:22, Kenneth wrote:
> "Kenneth" <kdw### [at] gmailcom> wrote:
>> Does your analysis of Kurtz's file indicate duplicate *triangles*, or just
>> duplicate vertices? Kurtz is converting his STL file to plain mesh AFAIU (not
>> mesh2)--
> My apologies; I was confusing your OBJ file discussion with STL file conversion.
Indeed, but that's okay.
And yes, I also have an obj2pov, stl2pov, eps2pov,  scripts.
kurtz le pirate
compagnie de la banquise
Date: 9 Oct 2025 03:36:08
Message: <68e765e8@news.povray.org>
On 08/10/2025 23:41, yesbird wrote:
>> just
>> AFAIU (not
>> mesh2)-- and in such files there are necessarily many duplicate
>> vertices, since
>> they are shared among some triangles. I'm guessing that your own mesh2
>> conversion code 'consolidates' those somehow-- resulting in fewer
>> vertices
>> overall.
>> conversion.
> I only answered the Kurtz's question about difference in of vertices in
> our results. There is no *.inc file in Kurtz's zip, so I grepped obj.
Sorry, I forgot the INC file.
Here now ;)
>> If so, is this consolidation or merging one of the 'efficiency'
>> benefits of
>> POV-ray's own mesh2 construct, or is it an extra operation that you
>> added to
>> your own conversion code?
> My conversion process is following:
> 1. Calling OBJLoader() from Three.js library to load meshes into scene.
> 2. Call standard Three.js mergeVertices() method for each mesh on load
> to build vertices index, that completely excludes duplicates.
> 3. Call my POVExporter(), which traverses scene, selects meshes and
> saves data to model.ini as mesh2.
> Very simple :)
kurtz le pirate
Download 'pingouin.inc.zip' (873 KB)
Date: 9 Oct 2025 04:52:54
Message: <68e777e6$1@news.povray.org>
Thanks for kind words, but still there is a space for improvement.
I hope more experienced POV-Ray community will help me to do that.
> them ;-)
It's a very unexpected, but interesting idea, I will consider it in
future, although supporting phones is painful because of too many
different resolutions. Right now I would like to concentrate on main
functionality and extending the materials library.
Btw, I am almost ready to make a proposal about integration to Blender's
developer, you, mentioned earlier, and will write it today.  Hope for
productive collaboration.
PS: Zoomers preferes games, vintage SDL is not for them ).
YB
Date: 9 Oct 2025 06:55:00
Message: <web.68e7947dc908933616086ed06830a892@news.povray.org>
> > them ;-)
> YB
I sent you an email.
Date: 10 Oct 2025 06:25:00
Message: <web.68e8de59c9089336e83955656e066e29@news.povray.org>
yesbird wrote:
> On 08/10/2025 18:29, kurtz le pirate wrote:
> > Have you noticed any improvements ?
> Yes, I am working hard and updating it daily, fixing the bugs and
> implementing new features.
I *just* noticed something odd about your online STL-to-mesh2 conversion
process. (I should have mentioned it before now, but was too busy working on my
own converter; my apologies.)
It seems that the resulting mesh2 triangles are facing 'inside out'-- the
insides face outside and vice versa. See my attached render of an STL (binary)
file that I uploaded to your page and converted tonight.
In the converted mesh2 file, I first deleted your union{...} and material{...}
at the end, then rendered the mesh2 with my own textures: A regular texture AND
an interior_texture.
However, this is NOT a fault of your conversion process: I noticed the same
behavior while working on my own POV-ray STL-to-mesh converter. The 3 vertices
in each STL triangle are apparently written the opposite way 'around the clock'
-- opposite chirality-- according to how *POV-ray* expects them. I had to fix
this in my own code, simply by swapping the triangles' 3rd point for the 1st.
Like:
an original STL triangle:
triangle{<1,2,3>, <4,5,6>, <7,8,9>}
for correct POV-ray rendering:
triangle{<7,8,9>, <4,5,6>, <1,2,3>}
STL files (and 3D printers) are apparently standardized for a 3-vertex chirality
that is opposite to POV-ray's own triangle-rendering scheme.
Download 'triangles_inside_out_kw_10_10_25.jpg' (20 KB)
Preview of image 'triangles_inside_out_kw_10_10_25.jpg'
