POV-Ray : Newsgroups : povray.binaries.utilities : Online files converter Server Time
25 May 2026 01:45:53 EDT (-0400)
  Online files converter (Message 70 to 79 of 106)
Subject: Re: Online files converter
Date: 6 Oct 2025 20:09:55
Message: <68e45a53@news.povray.org>
On 28/09/2025 01:27, yesbird wrote:
> Finally, after two sleepless nights I finished a web application that
> converts obj, fbx, glb, gltf, stl formats to mesh2 ...
Another update is ready - now materials can be assigned to different
parts of the model. The process is not convenient yet, but enough for
testing.
YB
Download 'deep_space.png' (183 KB) Download 'ring.png' (169 KB) Download 'ring_pov.png' (65 KB)
Preview of image 'deep_space.png'
Preview of image 'ring.png'
Preview of image 'ring_pov.png'
Date: 8 Oct 2025 11:29:12
Message: <68e68348@news.povray.org>
On 05/10/2025 14:58, yesbird wrote:
> Thanks for feedback, could you please provide a little bit more
> details - why can't you convert them ? And who else can't ?
> Please send me your OBJ and content of _console_ tab (F12).
Hum ... After another attempt today, my file loaded correctly and my
pingoin appears correctly.
Have you noticed any improvements ?
Another thing about my converter. I find 18,531 vertices, while you only
have 952.
I think that for very large meshes, the size of the converted file with
18 digits increases enormously without providing any additional precision.
4 or 6 digits should suffice and would reduce the size by more than four
times (18/4=4.5).
Good job ;)
> The project is in beta state, so debug information is highly
> appreciated.
kurtz le pirate
compagnie de la banquise
Date: 8 Oct 2025 11:58:08
Message: <68e68a10$1@news.povray.org>
Yes, I am working hard and updating it daily, fixing the bugs and
implementing new features. Now working on material library and improving
studio environment.
> have 952.
I do merging on load, maybe this is the reason. Could you please send me
your file for testing ? Good bug report is the half of a successful fix
> times (18/4=4.5).
Agree with you and have already been included it in my TODO list.
> Good job ;)
Thanks for the kind words :).
YB
Date: 8 Oct 2025 12:10:55
Message: <68e68d0f@news.povray.org>
> studio environment.
>> only have 952.
Sure ! A zip file with the OBJ file and my INC file.
>> with 18 digits increases enormously without providing any additional
>> precision.
>> four times (18/4=4.5).
>> Good job ;)
> YB
kurtz le pirate
Download 'pingouin.zip' (746 KB)
Date: 8 Oct 2025 13:01:02
Message: <68e698ce@news.povray.org>
Thanks, merging is the reason, I see a lot of duplicates here:
grep -w v pingouin.obj  | tail -n 20
v 0.023851 0.00175495 0.0374573
PS: Attached pingouin inspired by Terminator-2 ).
YB
Download 'pingouin.png' (219 KB)
Preview of image 'pingouin.png'
Date: 8 Oct 2025 13:18:24
Message: <68e69ce0@news.povray.org>
> Thanks, merging is the reason, I see a lot of duplicates here ...
Z-Brush also report about unused vertices, please find optimized version
in attachment.
YB
Download 'pingouin_cleaned.zip' (458 KB) Download 'pingouin_zb.png' (351 KB)
Preview of image 'pingouin_zb.png'
Date: 8 Oct 2025 17:05:00
Message: <web.68e6d1b9c9089336e83955656e066e29@news.povray.org>
> (etc.)
Does your analysis of Kurtz's file indicate duplicate *triangles*, or just
duplicate vertices? Kurtz is converting his STL file to plain mesh AFAIU (not
mesh2)-- and in such files there are necessarily many duplicate vertices, since
they are shared among some triangles. I'm guessing that your own mesh2
conversion code 'consolidates' those somehow-- resulting in fewer vertices
overall.
If so, is this consolidation or merging one of the 'efficiency' benefits of
POV-ray's own mesh2 construct, or is it an extra operation that you added to
your own conversion code?
Date: 8 Oct 2025 17:25:00
Message: <web.68e6d627c9089336e83955656e066e29@news.povray.org>
> mesh2)--
My apologies; I was confusing your OBJ file discussion with STL file conversion.
Date: 8 Oct 2025 17:41:16
Message: <68e6da7c$1@news.povray.org>
> overall.
I only answered the Kurtz's question about difference in of vertices in
our results. There is no *.inc file in Kurtz's zip, so I grepped obj.
My conversion process is following:
1. Calling OBJLoader() from Three.js library to load meshes into scene.
2. Call standard Three.js mergeVertices() method for each mesh on load
to build vertices index, that completely excludes duplicates.
3. Call my POVExporter(), which traverses scene, selects meshes and
saves data to model.ini as mesh2.
Very simple :)
YB
Date: 8 Oct 2025 20:25:00
Message: <web.68e7000bc9089336e83955656e066e29@news.povray.org>
> times (18/4=4.5).
In my own POV-ray-only stl-to-mesh converter-- not yet posted ;-) -- I came to
the same conclusion: that 4 or 5 digits were enough, and that more were simply
overkill. In my experience, some models' float values are written with much more
precision than is necessary.
HOWEVER, I am now thinking that it needs to be a 'dynamic' value-- based on the
number of triangles (or vertices) in the original file (whether .stl or .obj or
whatever type.)
Some files have a low-triangle count, others very high. As the number of
triangles increases, it usually means that they are smaller (for a given-size
object), to produce finer detail-- and thus require more precision in their
values. Otherwise, a 4-to-6 significant digit conversion process might create
unwanted duplicate values by truncating or rounding important digits. Here's an
example of my thinking:
an original float value in a LOW-triangle-count model:
69.5746344739 // probably overkill, since the triangles themselves are larger in
relation to the overall object. This could be reduced/rounded to 4 or 5 digits,
IMO, and still produce a perfectly adequate final model.
an original float value in a HIGH-triangle-count model:
69.5746344739 // all of those digits would probably be necessary, to prevent
duplicates due to rounding.
Then there are the middle cases between 'low' and 'high', of course.
I don't have a formula for creating such a dynamically-changing number of
significant digits-- because it is not yet clear as to what constitutes a low
triangle-count vs a higher one!-- but the idea might be worth pursuing.
