POV-Ray : Newsgroups : povray.binaries.utilities : POV-Tree: some (advanced?) recommendations Server Time
22 Nov 2026 20:48:57 EST (-0500)
  POV-Tree: some (advanced?) recommendations (Message 1 to 5 of 5)
Subject: POV-Tree: some (advanced?) recommendations
Date: 17 May 2013 04:37:18
Message: <5195ec3e$1@news.povray.org>
POV-Tree is an easy to use although not perfect utility by Gena Obukov,
to make different kinds of trees. It exports them as mesh{} objects
(/not/ mesh2{}!) to be used in POV-Ray scenes.
One of the problems is that the meaf meshes do not have consistently
oriented normals. The obvious solution is to make one's own leaf mesh
and use that as a Custom Mesh in the Leaf section of POV-Tree. The
following code is such a simple mesh I want to share with you.
//start code
triangle {<-0.380625,0,0.1>,<-0.480625,0,0.2>,<-0.480625,0,0.1>}
triangle {<-0.380625,0,-0.1>,<-0.480625,0,0>,<-0.480625,0,-0.1>}
triangle {<-0.380625,0,0>,<-0.480625,0,0.1>,<-0.480625,0,0>}
triangle {<-0.380625,0,-0.220856>,<-0.480625,0,-0.1>,<-0.480625,0,-0.2>}
triangle {<-0.080625,0,0>,<-0.080625,0,0.121029>,<-0.280625,0,0.1>}
triangle {<-0.280625,0,0>,<-0.380625,0,0.1>,<-0.380625,0,0>}
triangle {<-0.280625,0,-0.2>,<-0.380625,0,-0.1>,<-0.380625,0,-0.220856>}
triangle {<-0.280625,0,0.1>,<-0.380625,0,0.220856>,<-0.380625,0,0.1>}
triangle {<-0.280625,0,-0.1>,<-0.280625,0,0>,<-0.380625,0,0>}
triangle {<-0.280625,0,-0.2>,<-0.280625,0,-0.1>,<-0.380625,0,-0.1>}
triangle {<-0.280625,0,0.1>,<-0.280625,0,0.2>,<-0.380625,0,0.220856>}
triangle {<-0.280625,0,0>,<-0.280625,0,0.1>,<-0.380625,0,0.1>}
triangle {<-0.380625,0,0.1>,<-0.480625,0,0.1>,<-0.380625,0,0>}
triangle {<-0.380625,0,0>,<-0.480625,0,0>,<-0.380625,0,-0.1>}
triangle {<-0.380625,0,-0.1>,<-0.480625,0,-0.1>,<-0.380625,0,-0.220856>}
triangle {<-0.380625,0,0.220856>,<-0.480625,0,0.2>,<-0.380625,0,0.1>}
triangle {<-0.480625,0,-0.2>,<-0.480625,0,-0.1>,<-0.680625,0,-0.12253>}
triangle {<-0.680625,0,-0.12253>,<-0.680625,0,0>,<-0.880625,0,0>}
triangle {<0,0,0>,<-0.080625,0,0>,<-0.080625,0,-0.121029>}
triangle {<-0.080625,0,-0.121029>,<-0.280625,0,-0.1>,<-0.280625,0,-0.2>}
triangle {<-0.080625,0,-0.121029>,<-0.280625,0,0>,<-0.280625,0,-0.1>}
triangle {<-0.480625,0,-0.1>,<-0.680625,0,0>,<-0.680625,0,-0.12253>}
triangle {<-0.080625,0,0.121029>,<-0.280625,0,0.2>,<-0.280625,0,0.1>}
triangle {<-0.480625,0,0.1>,<-0.480625,0,0.2>,<-0.680625,0,0.12253>}
triangle {<-0.480625,0,0>,<-0.480625,0,0.1>,<-0.680625,0,0.12253>}
triangle {<-0.280625,0,-0.1>,<-0.380625,0,0>,<-0.380625,0,-0.1>}
triangle {<-0.080625,0,-0.121029>,<-0.080625,0,0>,<-0.280625,0,0>}
triangle {<-0.480625,0,-0.1>,<-0.480625,0,0>,<-0.680625,0,0>}
triangle {<-0.080625,0,0>,<-0.280625,0,0.1>,<-0.280625,0,0>}
triangle {<-0.480625,0,0>,<-0.680625,0,0.12253>,<-0.680625,0,0>}
triangle {<0,0,0>,<-0.080625,0,0.121029>,<-0.080625,0,0>}
triangle {<-0.680625,0,0>,<-0.680625,0,0.12253>,<-0.880625,0,0>}
//end code
Copy these triangles into the Custom Mesh window and you are in business.
Now, an interesting use of this well-normalized leaf mesh is to provide
the leaf with an interior_texture{} as leaves often have a lighter
underside.
Beware, for the following issue. It appears that the trunk and branches
mesh is inside out! In some situations, you may need to add the inverse
parameter to object {WOOD} in the tree file.
Hope you enjoy this.
Subject: Re: POV-Tree: some (advanced?) recommendations
Date: 18 May 2013 20:20:01
Message: <web.51981a00bc193e98c2d977c20@news.povray.org>
Thanks for your investigation into this. I haven't used POV-Tree yet, but it's
on my to-do list. Your recommendations will be useful.
I assume(?) that Gena is no longer actively updating the program. Do you have a
link to the 'latest' version? I did a web search and I can't tell which is the
latest one. v1.5?
Date: 19 May 2013 03:03:44
Message: <51987950@news.povray.org>
> latest one. v1.5?
Latest version seems to be 1.5b, assuming I have the latest version of
course ;-)
A pity that Gena is not actively involved into this anymore. There are a
number of improvements and bug fixes needed and - especially - a planned
mesh2 export which never saw the light.
Otherwise, POV-Tree is a nice tool which gives fairly good results,
especially as CSG output, which is the old TomTree macro by Tom Aust.
For close ups however, the mesh export is average imo, even with higher
resolutions. With higher memory usage the app becomes rather unstable too.
Date: 19 May 2013 04:25:05
Message: <51988c61$1@news.povray.org>
Using inverse, you may get a "Parse Warning: Cannot invert a patch
object." However, it seems to work nonetheless.
Date: 20 May 2013 04:03:26
Message: <5199d8ce@news.povray.org>
As the primary orientation of the leaves is unclear (it appears to be
along -x) my leaf was oriented towards +x. Here is a new leaf:
triangle {<0.380625,0,-0.1>,<0.480625,0,-0.2>,<0.480625,0,-0.1>}
triangle {<0.380625,0,0.1>,<0.480625,0,0>,<0.480625,0,0.1>}
triangle {<0.380625,0,0>,<0.480625,0,-0.1>,<0.480625,0,0>}
triangle {<0.380625,0,0.220856>,<0.480625,0,0.1>,<0.480625,0,0.2>}
triangle {<0.080625,0,0>,<0.080625,0,-0.121029>,<0.280625,0,-0.1>}
triangle {<0.280625,0,0>,<0.380625,0,-0.1>,<0.380625,0,0>}
triangle {<0.280625,0,0.2>,<0.380625,0,0.1>,<0.380625,0,0.220856>}
triangle {<0.280625,0,-0.1>,<0.380625,0,-0.220856>,<0.380625,0,-0.1>}
triangle {<0.280625,0,0.1>,<0.280625,0,0>,<0.380625,0,0>}
triangle {<0.280625,0,0.2>,<0.280625,0,0.1>,<0.380625,0,0.1>}
triangle {<0.280625,0,-0.1>,<0.280625,0,-0.2>,<0.380625,0,-0.220856>}
triangle {<0.280625,0,0>,<0.280625,0,-0.1>,<0.380625,0,-0.1>}
triangle {<0.380625,0,-0.1>,<0.480625,0,-0.1>,<0.380625,0,0>}
triangle {<0.380625,0,0>,<0.480625,0,0>,<0.380625,0,0.1>}
triangle {<0.380625,0,0.1>,<0.480625,0,0.1>,<0.380625,0,0.220856>}
triangle {<0.380625,0,-0.220856>,<0.480625,0,-0.2>,<0.380625,0,-0.1>}
triangle {<0.480625,0,0.2>,<0.480625,0,0.1>,<0.680625,0,0.12253>}
triangle {<0.680625,0,0.12253>,<0.680625,0,0>,<0.880625,0,0>}
triangle {<0,0,0>,<0.080625,0,0>,<0.080625,0,0.121029>}
triangle {<0.080625,0,0.121029>,<0.280625,0,0.1>,<0.280625,0,0.2>}
triangle {<0.080625,0,0.121029>,<0.280625,0,0>,<0.280625,0,0.1>}
triangle {<0.480625,0,0.1>,<0.680625,0,0>,<0.680625,0,0.12253>}
triangle {<0.080625,0,-0.121029>,<0.280625,0,-0.2>,<0.280625,0,-0.1>}
triangle {<0.480625,0,-0.1>,<0.480625,0,-0.2>,<0.680625,0,-0.12253>}
triangle {<0.480625,0,0>,<0.480625,0,-0.1>,<0.680625,0,-0.12253>}
triangle {<0.280625,0,0.1>,<0.380625,0,0>,<0.380625,0,0.1>}
triangle {<0.080625,0,0.121029>,<0.080625,0,0>,<0.280625,0,0>}
triangle {<0.480625,0,0.1>,<0.480625,0,0>,<0.680625,0,0>}
triangle {<0.080625,0,0>,<0.280625,0,-0.1>,<0.280625,0,0>}
triangle {<0.480625,0,0>,<0.680625,0,-0.12253>,<0.680625,0,0>}
triangle {<0,0,0>,<0.080625,0,-0.121029>,<0.080625,0,0>}
triangle {<0.680625,0,0>,<0.680625,0,-0.12253>,<0.880625,0,0>}
