POV-Ray : Newsgroups : povray.binaries.utilities : Clothsim problem Server Time
9 Oct 2026 04:36:14 EDT (-0400)
  Clothsim problem (Message 1 to 9 of 9)
Subject: Clothsim problem
Date: 11 Apr 2001 07:53:15
Message: <3ad445ab@news.povray.org>
I downloaded clothsim version 0.4.0 and I'm trying to
create a banner waving in the wind. I've tried with
simulation steps 5000,10000 and 20000 but everytime
I get a message saying that 1.04625e+301 (or some similarly
large number) is not finite. followed by
      0 [main] CLOTH 244807 handle_exceptions: Exception:
STATUS_ACCESS_VIOLATIO
N
    867 [main] CLOTH 244807 stackdump: Dumping stack trace to
CLOTH.EXE.stackdum
p
my input file was as follows
global_settings {
 step 0.25
 wind <0,-0.3,0>
cloth {
 x_size 50
 y_size 50
 dist 2/50
 stiffness 0.1
 weight 0.5
 position {<0,0,1>,<1,0,1>,<1,0,0>}
 attach {0,0,<0,0,0.17>}
 attach {1,0,<1,0,-0.17>}
Am I doing something wrong? I assume there's something
about the above input that the simulator doesn't like as I can run
the flag and sample files. I've tried on both a P3 450 and a P2 300
both with 128 MB ram.
Any help will be greatly appreciated.
Gail
* gsh### [at] monotixcoza                *   Step into the abyss,           *
* http://www.rucus.ru.ac.za/~gail/   *   and let go.        Babylon 5   *
* The difficult we do immediately, the impossible takes a little longer *
Subject: Re: Clothsim problem Addendum, OS info
Date: 11 Apr 2001 08:03:44
Message: <3ad44820@news.povray.org>
the p3 450 is running Win95 OEM2 and the p2 300 is
running win98
Gail
Date: 11 Apr 2001 08:24:45
Message: <3AD44BEA.4BEDED5C@videotron.ca>
Same here.
> I've tried with simulation steps 5000,10000 and 20000 but
> everytime I get a message saying that 1.04625e+301 (or some
> similarly large number) is not finite. followed by
Same here.
> global_settings {
>  step 0.25
>  wind <0,-0.3,0>
> cloth {
>  x_size 50
>  y_size 50
>  dist 2/50
>  stiffness 0.1
>  weight 0.5
Argh!!  Same here too!!! (except the z component)
Reduce the step to 0.1 or something similar.  That solved it for me,
although it takes 200 000 iterations before my flag looks like it has
moved a bit.
And if you haven't read my earlier post on the subject, be warned that
there's a typo in the strenght [sic] keyword.
Francois Labreque | It is by caffeine alone I set my mind in motion, it
    flabreque     | is by the beans of Java that thoughts acquire speed,
        @         | the hands acquire shaking, the shaking becomes a
   videotron.ca   | warning, it is by caffeine alone I set my mind in
                  | motion.
                               - Stolen from Badger's .sig file
Date: 11 Apr 2001 09:02:54
Message: <3ad455fe@news.povray.org>
Francois Labreque <fla### [at] videotronca> wrote in message
news:3AD44BEA.4BEDED5C@videotron.ca...
> moved a bit.
I've tried 0.1, 0.2 and 0.25 all with the same problem. Will try smaller
tonight
I did read it but forgot. That explains why the sample wouldn't work.
Thanks
Gail
Date: 11 Apr 2001 14:47:14
Message: <3ad4a6b2@news.povray.org>
"Gail Shaw" <gsh### [at] monotixcoza> wrote in message
news:3ad445ab@news.povray.org...
You shouldn't need anything like this number of steps.
> N
> CLOTH.EXE.stackdum
> p
I believe this is mainly down to the fact that you are creating such a small
piece of cloth ( dist 2/50 ), and the way it interacts with stiffness etc. I
think you'd be better off creating a large flag ( e.g dist 1 ), and scaling
it smaller. Also, a value of 50 for the x and y is way over the top. You
could get away with 20, but 25 would be better. This will also help with the
parse time.
> global_settings {
>  step 0.25
>  wind <0,-0.3,0>
> cloth {
>  x_size 50
>  y_size 50
>  dist 2/50
>  stiffness 0.1
>  weight 0.5
I'm unsure as to what you're trying to achieve.. I did a test render (having
scaled up the cloth), and it looked like your attatch points are at the
lower corners of the flag/banner... so the cloth would have to fall a long
way AND back on itself to be where it should be with regard to the wind (I
think... attatch points and position still cause me great headaches :-) )
If you tell me the coordinates of where the flag should be in your scene,
I'd be happy to send you a *.cl file.
All the best,
Andy
Date: 11 Apr 2001 14:47:16
Message: <3ad4a6b4$1@news.povray.org>
"Francois Labreque" <fla### [at] videotronca> wrote in message
> Same here.
Did you know that in the source code there is example code of a flag
animation?
> moved a bit.
You should be able to use just 25 steps between each frame.. nothing like
200 000. See the example file above. It uses -s 25 between frames.
Andy
Date: 12 Apr 2001 01:52:34
Message: <3ad542a2@news.povray.org>
Andy Cocker <big### [at] mariner9fsnetcouk> wrote in message
news:3ad4a6b2@news.povray.org...
(having
I was getting very confused with the coord system.
(x positive to the right, y positive into scene, z positive up. Is that
correct?)
I'm used to the left handed system
I was trying for a banner attached to a pole top left and right (one side
slightly
lower than the other)
Thanks for all the suggestions. I'll have another try with it tonight.
Gail
Date: 12 Apr 2001 13:04:23
Message: <3ad5e017@news.povray.org>
news:3ad542a2@news.povray.org...
> correct?)
That's correct.
Me too.
You're welcome.
Andy
Date: 18 Apr 2001 06:23:50
Message: <3add6b36@news.povray.org>
All is now working. It helps if the position vectors are
sensible which
is not
Thanks to everyone who gave suggestions.
Gail
