POV-Ray : Newsgroups : povray.binaries.utilities : Converting a COB file Server Time
9 Oct 2026 04:36:13 EDT (-0400)
  Converting a COB file (Message 1 to 7 of 7)
Subject: Converting a COB file
Date: 30 Nov 2000 08:31:29
Message: <3a2656b1@news.povray.org>
Hi all,
I downloaded a model of a dirt mover from 3DCafe. The file is in COB format.
What is a COB file and how do I convert it so that I can import it into POV?
Thanks
Reuben
Subject: Re: Converting a COB file
Date: 30 Nov 2000 08:35:54
Message: <3A26586B.8E1069BE@pacbell.net>
Reuben Pearse wrote:
> Hi all,
Try this conversion program. It should be able to convert it to a
a traingle mesh for you.
http://www.europa.com/~keithr/crossroads/
Date: 30 Nov 2000 19:08:37
Message: <3a26ec05$1@news.povray.org>
I also found that if you use crosswinds to a RAW format, you can use
"Triangles" (a DOS program) to covert the RAW file to a smooth triangle
mesh!
www.geocities.com/Athens/Academy/8764/triangles.htm
Enjoy,
C.J. - POV User
POV Ray Study Gallery
www.crosswinds.net/~povstudy
hou### [at] yahoocom
Ken <tyl### [at] pacbellnet> wrote in message
news:3A26586B.8E1069BE@pacbell.net...
> > Hi all,
format.
POV?
> Ken Tyler - 1400+ POV-Ray, Graphics, 3D Rendering, and Raytracing Links:
Date: 30 Nov 2000 20:17:12
Message: <3A26FCCA.42A9E047@pacbell.net>
> mesh!
Then again you simply instruct Crossroads to do it for you. It is
a built in feature and would decrease the number of steps necessary
to accomplish the same thing.
Ken Tyler
Date: 5 Dec 2000 00:33:01
Message: <3a2c7e0d$1@news.povray.org>
I have not seen where to do that in crossoads Ken. Where is it?
C.J. - POV User
news:3A26FCCA.42A9E047@pacbell.net...
> > mesh!
> Ken Tyler
Date: 5 Dec 2000 00:56:50
Message: <3A2C8467.321FC867@pacbell.net>
Load an object.
Click on that object or you can select multiple objects if they
exist (their color will change when selected). You can also
"select all" from the edit menu or by right clicking on the
work screen.
Right click on the work screen.
You should now see a menu with various options including the
smooth option.
Select it for that object(s).
When exporting it will automatically create smooth triangles
for the mesh object it creates.
Cheers,
Date: 5 Dec 2000 20:24:58
Message: <3a2d956a@news.povray.org>
Cool!
Thanks Ken, Now I will run off to play...
C.J. - POV User
news:3A2C8467.321FC867@pacbell.net...
> Load an object.
> work screen.
> smooth option.
> Cheers,
