Subject: POV-Ray 3.5 makefile for Inprise (Borland) free command-line tools
Date: 3 Oct 2002 18:19:45
Message: <3D9CC349.8080502@starman.ee>
As subject says :-) File contains readme file with detailed instructions.
Download 'borland.zip' (5 KB)
Subject: Re: POV-Ray 3.5 makefile for Inprise (Borland) free command-line tools
Date: 3 Oct 2002 19:34:16
Message: <3d9cd3f8$1@news.povray.org>
Wow! Talk about detailed. That's a lot of work to get POV to compile. I'm
about to try it out. Thanks in advance for all the hard work you put into
this, Vahur! I know I wouldn't have had the time or knowledge to do it all
alone.
Anthony Bennett
Date: 3 Oct 2002 23:31:14
Message: <3d9d0b82@news.povray.org>
Success! Thank you!! :-D
Anthony
Date: 4 Oct 2002 15:29:35
Message: <3D9DECEA.6090907@starman.ee>
De nada!
But if You think, that mere 'Thank you' is sufficient, then think again!
Now You have to provide some investment return (i.e. patches, defect
corrections etc.)!
j/k, of course:-)
But seriously talking I'd like to know, whether there were omissions or
shortcomings in documentation or makefile in order to improve them. I
finished this ca. 1.30 AM (4 hours past usual bed-time!!!, but I got hit
by this can't-stop-before-finished flow!) and I'm not very sure, that
readme is quite readable or understandable by others. So if you have (or
someone else has) suggestions or corrections, then I'd like to hear them!
Date: 4 Oct 2002 18:16:13
Message: <3d9e132d$1@news.povray.org>
> corrections etc.)!
Of course! That was the whole point of compiling POV. :) It will be a long
time before you see anything from me, though. The code looks perfect to my
inexperienced eyes, so rather than trying to optimize what they've got there
right now, I'll be doing research into (dare I say) better algorithms which
produce at least equally good results. Wish me luck! :)
Only thing that I had to do was find htmlhelp.lib and winmm.lib. I used
implib (as per a suggestion on some site I've lost the URL to) to extract
winmm.lib from system32\winmm.dll. Oh, and I renamed it .obj. I have no idea
whether this is good or bad, all I know is that POV compiled and hasn't
crashed yet... It's just very slow compared to the official binary. About
half speed. :(
Anthony
Date: 5 Oct 2002 05:44:53
Message: <3D9EB55E.700@starman.ee>
> crashed yet...
Which Windows version you have? In my system (W2K) there was no need for
winmm.lib.
> half speed. :(
You get what you pay for: Inprise compiler does not produce so good
code, as MS, Intel or gcc. Did you compiled optimized version of it? By
default makefile has debug compiler flags (without any optimization) in
order to make debugging easier. Although to me it seems, that these
optimizing flags do nothing, it will produce code, which has same speed :-(
On Fri, 04 Oct 2002 22:32:58 +0300, Vahur Krouverk <vkr### [at] starman ee>
I will check it. Thank for your effort.
ABX
On Fri, 4 Oct 2002 18:16:01 -0400, "Tony[B]" <ben### [at] catholic org> wrote:
> crashed yet...
That's wrong IMO. I have thought about that problem and found the reason.
First of all You don't have to extract winmm.lib from dll. It is already
present in free borland but not in main LIB\ but in subfolder LIB\PSDK.
And you don't have to rename it to obj. It can be linked directly as
winmm.lib. Just make optional two pragmas from pvengine.c.
#ifndef __BORLANDC__
#pragma comment(lib, "htmlhelp")
#pragma comment(lib, "winmm")
#endif
> half speed. :(
Exactly. Standard benchmark started on Win95 with PII 233 128 MB
POVWin - 13h 51m 14s
PoPOVWin - 7h 00m 24s
ABX
Date: 27 Oct 2002 03:33:42
Message: <3DBBA4F0.1090602@starman.ee>
>>crashed yet...
> #endif
I looked at my code and I stand corrected in my previous statement (_In
my system (W2K) there was no need for winmm.lib._): as it appears, i've
commented out both pragma directive lines in pvengine.c and therefore it
linked OK in my case. So best solution for given problem would be indeed
to make these pragmas conditional as above.
On Sun, 27 Oct 2002 10:33:52 +0200, Vahur Krouverk <vkr### [at] starman ee>
Vahur, since you are only brave to play with free borland compilation process,
would you like to try prepare compilation of povcmax2.dll and cmedit.dll using
notes written in $(POV35winsrc)\windows\readme.txt ? Is it mission imposible
with free borland ?
ABX
After some effort of course, trying to figure out what was meant by all the
talk of htmlhelp.lib and winmm.obj.
I had gotten a htmlhelp.lib from out of a zip of the HTML Help documentation
at http://www.microsoft.com/downloads/release.asp?releaseid=33071
And I also did what Tony tried for using the winmm.lib, which was to copy it
from BCC55\LIB\PSDK and rename it with that obj extension. I wasn't
successful no matter how I tried, don't know if that's because of Windows XP
here or my lack of know-how.
If I had simply commented out those two lines in pvengine.c Vahur told of in
a reply to ABX I'd probably have saved myself the trouble. To be exact, I
mean this:
//#pragma comment(lib, "htmlhelp")
//#pragma comment(lib, "winmm")
// suggested to use instead by ABX:
//#ifndef __BORLANDC__
// #pragma comment(lib, "htmlhelp")
// #pragma comment(lib, "winmm")
//#endif
I'm not clear about that identifier __BORLANDC__. Is that supposed to work
as-is? Or is that just a placeholder for the real name needed there. Guess I
could try it to find out...
This is the very first time I ever successfully compiled a program of any
kind. Having had looked over doing so for other programs in the past I never
knew I could actually do it until now. Only way this worked okay is due to
you, Vahur Krouverk, and I am grateful. Maybe I'll be able to continue to do
more later on.
P.S. program code is crazy stuff, like POV script times 100, I'll need a IQ
boost to deal with it.
Farewell,
On Tue, 29 Oct 2002 22:06:12 -0600, "hughes, b." <omn### [at] charter net>
It is supposed to work as is. Read pages on http://predef.sourceforge.net/
In case you are interested in internals of free borland you can download help
files from ftp://ftp.borland.com/pub/bcppbuilder/techpubs/bcb5/ .
Basic informations can be found in b5std.zip file. Be carefull to not
overwrite help from free borland becouse it is newest.
ABX
Subject: Re: POV-Ray 3.5 makefile for Inprise (Borland) free command-linetools
Date: 30 Oct 2002 13:15:01
Message: <3DC021B7.1050405@starman.ee>
> with free borland ?
I don't know, whether it is impossible or not. If I have time, then I'll
give it a try. But why? Do you really want to hack editor?
On Wed, 30 Oct 2002 20:15:19 +0200, Vahur Krouverk <vkr### [at] starman ee>
Yes. I had to use not nice hack to achive effect described in
http://news.povray.org/povray.unofficial.patches/28351/ . IMO it should be
done in editor code rather than in POV-Ray port.
ABX
Date: 30 Oct 2002 14:40:37
Message: <3DC035C4.7060705@starman.ee>
Hmm, XML editor? Why not to use XML Notepad?
<http://msdn.microsoft.com/library/default.asp?url=/library/en-us/dnxml/html/xmlpadfaq.asp>
On Wed, 30 Oct 2002 21:40:52 +0200, Vahur Krouverk <vkr### [at] starman ee>
It was easier for me to create patch with ready autocompletion and highliging
of docbook keywords than learning all this stuff
(http://www.dpawson.co.uk/docbook/docbookref.pdf). Note I have bought old,
cheap, used machine to work on POV patching and documentation. It is Pentium
75 MHz. Does XML Notepad works on it?
ABX
Date: 30 Oct 2002 15:53:56
Message: <3DC046F7.1010903@starman.ee>
ABX wrote:
> Note I have bought
> old, cheap, used machine to work on POV patching and documentation.
> It is Pentium 75 MHz. Does XML Notepad works on it?
I guess so (although my response was more in region of joke).
But MHz and processor type has nothing to do with coding productivity: I
wrote POVMan on 66 MHz 486 DX2 with 32 MB of memory and RedHat 6.1. Now
(since April 2001) I have 1GHz AMD Athlon with 256 MB of memory and
Windows 2000 Professional + RH 7.1 and hasn't yet released any new
version of POVMan. Commitment and availability of free time are more
important factors....
"ABX" <abx### [at] abx art pl> wrote in message
news:ufavrukrvjia21r1uervjkmrhp5f31mnnt@4ax.com...
work
Guess I
Oh, okay, thanks for letting me know. I had retried it but used the wrong
type bitmap splash screen, 24-bit not 8-bit, so once again I had commented
out your conditional lines thinking that was the problem. Haven't done it
over again (yet), maybe I'll get there eventually.
help
Couldn't say yet if I'll ever be able to figure out this crazy C++ coding
stuff but at least I'm finally looking into it, so thanks also for those
sources of info... whatever it's all about. :-)
