Something wrong with messenger:
just save the part below the -------------
as 82.py
import sys, os, string
from string import split
from os import spawnv, P_NOWAIT
from Tkinter import *
from tkFileDialog import askopenfilename, asksaveasfilename
# remettre dans ligne de params les parametres
# autosave avant render
class mainWin:
def __init__(self,tkRoot):
self.tkRoot=tkRoot
self.createWidgets()
return None
global params
global filename
plat=sys.platform
class App:
## ---------------------- Create GUI ----------------------
def __init__(self, master):
## ---------------------- Mainframe ----------------------
mframe = Frame(master)
# mframe.title(text"POV-RAY Editor")
mframe.pack(expand=1, fill=BOTH)
frame_input=Frame(mframe)
## ---------------------- Menu ----------------------
menubar=Menu(frame_input)
filemenu=Menu(menubar,tearoff=0)
filemenu.add_command(label="New",command=self.clr)
filemenu.add_command(label="Open",command=self.enter_text)
filemenu.add_command(label="Save",command=self.save)
filemenu.add_command(label="Save As",command=self.saveas)
filemenu.add_separator()
filemenu.add_command(label="Quit",command=sys.exit)
menubar.add_cascade(label="File",menu=filemenu)
editmenu=Menu(menubar,tearoff=0)
editmenu.add_command(label="Cut")
editmenu.add_command(label="Copy")
editmenu.add_command(label="Paste")
menubar.add_cascade(label="Edit",menu=editmenu)
rendermenu=Menu(menubar,tearoff=0)
rendermenu.add_command(label="Render", command=self.render)
menubar.add_cascade(label="Render",menu=rendermenu)
root.config(menu=menubar)
## ---------------------- Buttons ----------------------
frame_buttons=Frame(mframe)
self.button_open = Button(frame_buttons, text="Open..", fg="blue",
self.button_open.pack(side=LEFT)
self.button_render = Button(frame_buttons, text="Render..[Alt+g]", fg="red",
self.button_render.pack(side=LEFT)
frame_buttons.pack(expand=0, fill=BOTH)
## ---------------------- Editor ----------------------
self.text = Text(frame_input)
self.yscroll_i = Scrollbar(frame_input,orient=VERTICAL,
command=self.text.yview)
self.yscroll_i.pack(side=RIGHT, fill=Y)
self.text['yscrollcommand']=self.yscroll_i.set
self.text.pack(side=LEFT,expand=1, fill=BOTH)
self.text.bind("<KeyPress>", self.keyPress)
self.text.bind("<ButtonPress>", self.keyPress)
self.text.bind("<Alt-KeyPress-g>", self.render_kb)
frame_input.pack(expand=1, fill=BOTH)
## ---------------------- Output ----------------------
frame_output=Frame(mframe)
self.text_out = Text(frame_output,state=NORMAL,height=6)
self.text_out.pack(side=LEFT,expand=1, fill=BOTH)
self.scroll = Scrollbar(frame_output, command=self.text_out.yview)
self.text_out.configure(yscrollcommand=self.scroll.set)
self.scroll.pack(side=RIGHT, fill=Y)
frame_output.pack(expand=1, fill=BOTH)
## ---------------------- Status Bar ----------------------
frame_status_bar=Frame(mframe)
self.parameters = Label(frame_status_bar,text="Parameters : ",
anchor="w",bg='gray70')
self.parameters.pack(side='left')
self.fill_params=Entry(frame_status_bar,bg='gray100')
self.fill_params.insert(INSERT,"+w320 +h240 -f +dgt +p")
self.fill_params.pack(side='left', expand=1, fill=BOTH)
self.status_filename1 = Label(frame_status_bar,text="File : ",width=5,
self.status_filename1.pack(side=LEFT )
self.status_filename2 = Label(frame_status_bar,text="",width=20,relief=SUNKEN,
anchor="w", bg="gray90")
self.status_filename2.pack(side=LEFT)
self.status_line = Label(frame_status_bar,padx=1,
relief=SUNKEN,bg="gray90",
width=10,
anchor="w",
textvariable=affi_Ligne)
self.status_line.pack(side='right')
self.status_linetext = Label(frame_status_bar,padx=1,bg='gray70',
width=7,
anchor="w",
text="Line : ")
self.status_linetext.pack(side='right')
frame_status_bar.pack(side=LEFT,expand=1, fill='x')
## ---------------------- Open file ----------------------
def enter_text(self):
filetypes = ( ( "Pov files","*.pov"), ( "Include files","*.inc"), (
"All","*"))
self.filename = askopenfilename(filetypes=filetypes)
if self.filename:
self.text.delete(1.0, END)
fd = open(self.filename)
for line in fd.readlines():
if line.endswith("\r\n"):
line = line[:-2] + "\n"
self.text.insert(END, line)
fd.close()
self.status_filename2.config(text=os.path.split(self.filename)[1])
## ---------------------- Clear ----------------------
def clr(self):
## ---------------------- Save ----------------------
def save(self, forPrt=None):
try:
script = self.text.get(1.0, END)
if script:
fd = open(self.filename, 'w')
for line in string.split(script, '\n'):
fd.write(line)
fd.write('\n')
fd.close
except:
self.saveas()
## ---------------------- Saveas ----------------------
def saveas(self, forPrt=None):
if script:
# global filename
# self.filename=".pov"
self.filename = file = asksaveasfilename()
fd.write(line)
fd.write('\n')
fd.close
## ---------------------- Render button ----------------------
def render(self):
global params
params=self.fill_params.get()
if script:
fd.write(line)
fd.write('\n')
fd.close
app = '/usr/bin/x-povray'
# appli = split(app)[1]
# os.spawnl(os.P_NOWAIT, app , params)
# os.popen3(app +' '+params)
# os.system("dir" +params+" foo.txt 2>foo.error.txt")
spawnv(P_NOWAIT, app , ('x-povray', "+i"+self.filename+" "+params))
## ---------------------- Render keyboard ----------------------
def render_kb(self,event):
global params
app = r"C:\perso\bureautique\Microsoft Office\Office\excel.exe"
# os.system(app +' '+params)
# os.system(app)
spawnv(P_NOWAIT, app, (appli, params))
## ---------------------- Top-Level Command line button ----------------------
def parameters_button(self):
self.tl=Toplevel()
self.lb=Label(self.tl, text="Render parameters:")
self.cl=Entry(self.tl,width=40)
self.ok=Button(self.tl, text="OK", fg="red", command=self.get_parameters)
self.ok.pack(side=BOTTOM)
self.cl.pack(side=RIGHT)
self.lb.pack()
## ---------------------- Prints the current line number and contents
def lin(self):
tindex = self.text.index(INSERT)
Ligne, column = map(int, string.split(tindex, "."))
valeur=int((Ligne))
affi_Ligne.set(valeur)
## ---------------------- Called when a key is pressed ----------------------
def keyPress(self,event):
self.lin()
root = Tk()
affi_Ligne=StringVar()
#params=StringVar()
larg = root.winfo_screenwidth()
haut = root.winfo_screenheight()
root.maxsize()
# root.geometry("%dx%d+0+0" % (larg,haut))
app = App(root)
root.mainloop()
