POV-Ray : Newsgroups : povray.binaries.utilities : Checkers of textures Server Time
26 May 2026 17:55:50 EDT (-0400)
  Checkers of textures (Message 1 to 10 of 10)
Subject: Checkers of textures
Date: 16 Feb 2000 15:10:38
Message: <38AB03B2.AA13DE53@netvision.net.il>
Pigment {checker texture{...} texture{...}} doesn't work... any ways to
fix it? or checker only works
for colors?
Subject: Re: Checkers of textures
Date: 16 Feb 2000 15:49:12
Message: <38ab0d48@news.povray.org>
box {-1,1
        texture {checker
                texture {pigment {granite color_map {[0 color rgb 0][1 color rgb
1]}}}
                texture {pigment {wrinkles color_map {[0 color rgb 0][1 color
rgb 1]}}}
"Eitan Tal" <eit### [at] netvisionnetil> wrote in message
news:38AB03B2.AA13DE53@netvision.net.il...
| for colors?
Date: 16 Feb 2000 19:06:42
Message: <iDirOH8Hx=7CAL66c1nmMoehC1If@4ax.com>
On Wed, 16 Feb 2000 22:08:18 +0200, Eitan Tal
>for colors?
How about a comma between the two texture entries?
Peter Popov
pet### [at] tagpovrayorg
ICQ: 15002700
Date: 16 Feb 2000 19:27:15
Message: <38AB4020.BABCB9C0@pacbell.net>
> >for colors?
You can't use texture statements inside a pigment statement.
texture { checker
           texture {...}
           texture {...}
Date: 16 Feb 2000 20:41:06
Message: <DlCrOOUv3iVDrg4QKGPIxhZqNm6j@4ax.com>
Yes you can. This works:
sphere
{ 0, 5
  texture { checker texture { T_Wood1 }, texture { T_Wood2 } }
It also works if you replace the texture identifies with texture
declarations. It even works with the comma left out even though
technically it should parse it as a two-layer texture and a void
texture (i.e. the second entry in the checker pattern should default
to whatever it defaults for textures)
Peter Popov
ICQ: 15002700
Date: 16 Feb 2000 21:02:29
Message: <38AB5670.D7AB0A0C@pacbell.net>
> sphere
> { 0, 5
Your missing the point, Peter. The original posters example was:
pigment {checker texture{...} texture{...}}
You said to add a comma. It just won't work because he is trying to
use textures in a pigment statement. I was right when I said you
were wrong :)
Date: 16 Feb 2000 21:20:24
Message: <wFmrOGCXpxUi5zqLBk=vCTb4FtQR@4ax.com>
>were wrong :)
I admit. Guilty. Please have mercy oh mighty Ken. How dare I doubt
your knowledge! :)
Upon a second look I see why I missed that pigment word the first
time. It's capitalized. My POV-keyword-only filter must have rejected
it.
Peter Popov
ICQ: 15002700
Date: 16 Feb 2000 21:24:55
Message: <38AB5BB4.2D696EE8@pacbell.net>
> your knowledge! :)
You are free to doubt my knowlege because I sure do sometimes.
Date: 19 Feb 2000 02:44:46
Message: <38AE495F.2409B92A@netvision.net.il>
huh? that sphere he mentioned worked here.
is there some difference between metals and woods? because as long as I can
use
texture....
Ken wrote:
> > your knowledge! :)
> Ken Tyler -  1300+ Povray, Graphics, 3D Rendering, and Raytracing Links:
Date: 19 Feb 2000 03:02:14
Message: <38AE4DB7.DACC22A1@pacbell.net>
> use
> texture....
You can use textures inside a texture statement like the one example
that Peter provided.
This IS OK - texture { checker texture{...} texture{....} }
You cannot use textures inside a pigments statement like the example
you provided.
This is NOT OK - pigment { checker texture{....} texture{....} }
 If you need to use different pigment patterns inside a pigment statement
you could do it like this this example illustrates -
#declare Pig1 = pigment{checker color rgb 0 color rgb 1}
#declare Pig2 = pigment{hexagon color red 1 color green 1 color blue 1}
box { -1,1
           pigment { checker
                     pigment { Pig1 scale .5 }
                     pigment { Pig2 rotate 90*x scale .5 }
