This program is a small utility to view and convert 3D
files to a number of other 3D formats. It can generate
smooth triangles for those formats that support it,
allowing you to specify the angle under which the
faces should be smoothed. Additional each mesh could
be sized and unified (correcting bad face normals).
3DWin 3.1 is available at
http://ourworld.compuserve.com/homepages/thbaier/tools.htm
Whats new:
- memory usage reduced to 10%
- unifying speed factor up to 10 times faster
- support for text files DOS/UNIX/MAC added
- plugin report
- command line support
- OpenGL Export
- added new version of Imagine out format
- WaveFront Export
- WaveFront Import
- automated recognition of linedelimiter for import textfiles
Import:
Generic ASCII format (*.raw)
3dStudio (*.3ds, *.prj)
Imagine (*.obj, *.iob)
Lightwave (*.lwo)
Autodesk (*.dxf)
POV-Ray (*.pob)
WaveFront (*.obj)
Export:
3dStudio (*.3ds, *.asc)
Lightwave (*.lws, *.lwo)
Autodesk (*.dxf)
RenderWare (*.rwx)
VRML 1.0 (*.wrl)
HighLight (*.obt)
Direct X format for Microsoft (*.x)
Real 3D (*.rpl, *.obj)
POV-Ray and Moray (*.inc, *.udo)
Polray and Moray (*.inc, *.udo)
WaveFront (*.obj)
OpenGL (*.C)
© by Thomas Baier 1998
