Shawn Fumo's POV-Ray Utilities List
Release 4 -- May 31, 1997
Part 2 of 3
3 -- Object Generators
3.1 -- Lsystems/Trees
----Lparser----
Author: Laurens Lapr‚ -- ljl### [at] xs4all nl
Work: Lau### [at] cmg nl
Version: 4.0
Platform: MSDOS/Windows(in a dos box)
Tryout Type: Freeware
Export: RenderStar/POV(2.2+)/DXF/RAW/BLB/WRL
WWW: http://www.xs4all.nl/~ljlapre/index.html
----LSys32----
Author: Chris Lichti -- Home: chl### [at] mindspring com
Work: chlichti+@cs.cmu.edu
Version: beta? (2/5/97)
Platform: Windows
Tryout Type: Free
WWW: http://www.mindspring.com/~chlichti/html/lsys32.html
Notes: A graphical front-end program for Lparser 4.0
----PTD Nested Loop Trees----
Author: Paul T. Dawson -- ptd### [at] voicenet com
goo### [at] geocities com
Version: First released version (no ver. #)
File Type: Include File
WWW: http://www.voicenet.com/~ptdawson/tree.htm
----RTEvol (RayTraced Evolution)----
Author: Nguyen Duc Cuong -- juh### [at] rz tu-ilmenau de or
cn1### [at] irz inf tu-dresden de
Version: 1.0Beta_PatchLevel #2
Platforms: Win95/NT--SunOS(5.5)--Irix(5.3)
Export: Any raytracer/renderer using an ascii file fomat.
Source Code: No
WWW: http://www.rz.tu-ilmenau.de/~juhu/GX/RTEvol/index.html
Notes: The new version (due to be out anytime now) will support
animation and raycasting.
----SelfTree----
Author: Stephan Kuhagen -- stk### [at] informatik uni-bremen de
Version:
WWW: http://www.informatik.uni-bremen.de/~stk/trees/trees.html
----TreeForm----
Author: Peter Shafer -- dea### [at] europa com
Version: 1.00
Platform: MSDOS--Windows(in DOS box)
Export: UDO(Moray 2+)--CTDS(3.0+)
WWW: http://www.europa.com/~dearmad/dork.htm
Notes: Comes with CTDS (Connect The Dots) 3.0
----TREE.EXE----
Author: Jim ? -- val### [at] ionet net
Version: 1.2?
Platform: ?
Export: POV(3.0)--Polyray(1.8)
WWW: http://www.ionet.net/~valmill/
----Tree.POV----
Author: Sonya Roberts -- son### [at] geocities com
Version: 2.0
WWW: http://www.geocities.com/SoHo/Lofts/1022/
3.2 -- Geodesic Domes
----DOME----
Author: Rick J. Bono -- rjb### [at] hiline net
Marc St-Jean -- mar### [at] qcc sk ca (MacOS Port)
Version: 4.6
Platform: MSDOS--UNIX--MacOS
Tryout Type: Freeware (GNU)
Export: DXF/POV/WRL/DAT/PRN
Source Code: Yes (Borland C++)
No unix binaries but has Unix/Linux defines + makefile for
compilation onto Linux, etc.
WWW: http://www.cris.com/~rjbono/html/domes.html
FTP: ftp://ftp.teleport.com/pub/users/pdx4d/bin/dome46.zip (MSDOS)
Description: Command-line geodesic dome maker. Supports Tetrahedron,
Octahedron & Icosahedron Polyhedron types. Generates Symmetry
Triangles and Full Spheres for Class I & II Structures.
"Buckyball" Structuring (now includes all three polyhedron types).
Elliptical Geodesics, and functions for calculating Point,
Edge & Face Coordinates.
Notes: Also includes a DXFtoPOV utility.
----Geodome----
Author: ?
Version: ?
Platform: MSDOS
Tryout Type: ?
Interface Type: Command-line
Export: POV include file.
Source Code: Yes
WWW: http://www.dhc.net/~swallace/review1.htm#dome
3.3 -- Legos
----L3G0----
Author: Paul Gyugyi -- pau### [at] gyugyi com
WWW: http://www.gyugyi.com/l3g0/
----L3G0 for POV-Ray----
Author: Filip Spacek -- spa### [at] geocities com
Version: ?
WWW: http://www.geocities.com/SiliconValley/Park/6522/
Notes: This is just a conversion of the origional L3G0:
See above.
(*)----L3G0studio----
Author: Filip ? -- spa### [at] geocities com
Version: Early beta
Platform: MSDOS?
Notes: Supports 4 of the include files so far.
Description: Graphical Modeller for L3G0 library for POV-Ray.
3.4 -- Fonts
POV-Ray 3 now has a built in object for TrueType Fonts. However,
there are several cases where a utility may come in handy. If you
don't have POV-Ray 3, you need rounded fonts, have fonts other
than TrueTypes, to help with positioning, need a triange mesh for
warping, etc.
----Font3D----
Author: Squid? -- squ### [at] ksu ksu edu
Version: 1.60
Platform: MSDOS(binary)--Sun/Solaris(source)--SGI/IRIX or
HP/UX (reported little or no changes needed for source).
Source Code: Yes (for UNIX)
Import: TrueType (PC or Mac type)
Export: POV(2.x/3)--Radiance(2.x)--Vivid(2)--DXF--RIB--RAW
WWW: http://www-personal.ksu.edu/~squid/font3d.html
Description: Lets you make fonts for various 3D programs.
Features include beveling (flattened or rounded), store
demension info. in output file, use seperate textures for
different parts (faces/bevels/sides), and more.
----Font.inc----
Author: Michael D Johnson -- mdj### [at] voyager net
Version: 0.3
WWW: http://quark.vpplus.com/~redbeard/raytrace/POVRay-Util.html
Description: From Author "This is a POVRay 3.0 'text' object utility.
It gives the size of a single character or string and will also return
a single character text object centered at the origin on it's baseline.
It will also place letters of a string in an arc or curve in several
different ways."
----5x7LED.inc----
Version: 1.1
Descripton: By Author "A font to create digital LED readouts, similar
to those scrolling message boards, or pinball games, or any number
of other things. Now supports square LEDs, adjustable LED size, and
blob based LEDs (!)."
----VVFont----
Author: ?
Import: BGI (borland font files)
Export: POV (maybe with CTDS?)
WWW:?
FTP:?
Description: Takes in BGI files, and makes rounded fonts for use
with POV-Ray
3.5 -- Molecular
(*)----CPK----
Author: Eric G. Suchanek -- suc### [at] pg com
suc### [at] iac net
Version: 2.5
Platform: Amiga
Import: PDB
Export: POV
WWW: http://www.iac.net/~suchanek/cpkf/cpk.html
----MolMol----
Author: Reto Koradi -- kor### [at] mol biol ethz ch
Version: 2.4
Platform: Win95/NT --IRIX(4/5)--SunOS(4.x)--Solaris(2.x)--
AIX--OSF/1--Linux
Import: Residue Library--PDB--DIANA--DG--SYBYL(Mol2)--XYZ
Export: Residue Library--PDB--DIANA--DG--SYBYL(Mol2)--XYZ--
PostScript--MIF--EMF--TIFF--JPEG--PNG--BMP--POV--VRML
Source Code: Yes
WWW: http://www.mol.biol.ethz.ch/wuthrich/software/molmol/
http://bamsoft.software.bruker.de/packages/molmol/molmol.html
FTP: ftp.mol.biol.ethz.ch/pub/software/MOLMOL/
ftp.spectrospin.ch/pub/sag/MOLMOL/
ftp.bruker.de/pub/bruker/MOLMOL/
ftp.bruker.com/pub/nmr/mirror.bruker.de/MOLMOL/
Notes: Uses display systems: GL, OpenGL, XGL, X11, or TTY
Description: Very in depth program for creating, viewing,
plotting, and exporting Molecular Models.
(*)----MolPOV----
Author: Professor David E. Richardson -- der### [at] chem ufl edu
Version: 1.1
Platform: Win95/3.1
Tryout Type: Freeware?
WWW: http://www.chem.ufl.edu/~der/der_pov2.htm
(*)----pdb2pov----
suc### [at] iac net
(Mac Port) Richard Rothwell -- ?
Version: 1.21
Platform: Amiga/Mac/SGI
WWW: http://www.iac.net/~suchanek/pdb2povf/pdb2pov.html
Older: http://www.intcom.net/~suchanek/pdb2povf/pdb2pov.html
----PovChem----
Author: Paul Thiessen -- pau### [at] ludwig scs uiuc edu
Version: 1.00
Platform: Binaries for: MSDOS--Irix(5.x)--MAC(68k/PPC)
Source Code: Yes: ANSI C (no graphics)
Import: PDB (Widely used textual chemistry format)
Export: POV(2.2+)
WWW: http://ludwig.scs.uiuc.edu/~paul/PovChem.html
Notes: This program does not actually let you build models
from scratch. To do this, you must either use a seperate
program or code the PDB by hand. It's purpose is to let
you make various types of graphical models (CPK, Ball and
Stick, etc.) which can be rendered using POV-Ray. It also
includes some animation support.
(*)----Re_View----
Author: Jeffrey J. Gosper -- Jef### [at] brunel ac uk
Version: 1? (2 is in final testing phase, but can only get
it by emailing author. Has also begun work on 3)
Platform: Win3.1
Tryout Type: Free for single user. Site licence needed for more.
WWW: http://www.brunel.ac.uk/depts/chem/ch241s/re_view/re_view.htm
http://www.softshell.com/Free/REVIEW/Re_View.html
(*)----Swiss-PdbViewer----
Author: Nicolas Guex -- ng4### [at] ggr co uk
Manuel C. Peitsch -- mcp### [at] ggr co uk
Version: 2.2
WWW: http://expasy.hcuge.ch/swissmod/Swiss-PdbViewer/mainpage.html
http://www.expasy.ch/spdbv/mainpage.htm
http://www.pdb.bnl.gov/expasy/spdbv/mainpage.htm
(*)----VMD (Visual Molecular Dynamics)----
Author: Theoretical Biophysics Group -- vmd### [at] ks uiuc edu
Version: 1.2b1
Platforms: IRIX(5.x/6.x)-- HP-UX(9/10)--Linux
Import: X-PLOR(PSF, PDB, and DCD)/Amber/CRD/Raster3D
"In addition, if Babel is installed, the following formats can
be automatically converted into PDB files and read into VMD:
Alchemy, AMBER PREP, Ball and Stick,
Biosym .CAR, Boogie, Cacao Cartesian,
Cambridge CADPAC, CHARMm, Chem3D Cartesian 1,
Chem3D Cartesian 2, CSD CSSR, CSD FDAT,
CSD GSTAT, Free Form Fractional, GAMESS Output,
Gaussian Z-Matrix, Gaussian Output, Hyperchem HIN,
Mac Molecule, Macromodel, Micro World,
MM2 Input, MM2 Ouput, MM3,
MMADS, MDL MOLfile, MOLIN,
Mopac Cartesian, Mopac Internal, Mopac Output,
ShelX, Sybyl Mol,
Sybyl Mol2, and XYZ."
Export: Raster3D/tkRaster3D/ART/POV/Radiance/VRML
Source Code: Yes
WWW: http://www.ks.uiuc.edu/Research/vmd/
FTP: ftp.ks.uiuc.edu/pub/mdscope/vmd/
Description: Not sure even where to start! Very extensive
program.
3.6 -- Lens Flares
----Lens Flare----
Author: Nathan Kopp -- nko### [at] sunny ncmc cc mi us
Version: 3.0
WWW: http://www.grfn.org/~nkopp/pov/flare1.shtml
----Lens Flare Include File----
Author: Chris Colefax -- cco### [at] geocities com
Version: No ver. numbers -- Latest in March
WWW: http://www.geocities.com/SiliconValley/Lakes/1434/
Gone-> http://lionfish.jcu.edu.au/~art-ilc/lensflare/
3.7 -- People
----Hero Ngauv's People plugin----
Author: Hero Ngauv -- mro### [at] juno com
Version: ?
WWW: http://www.televar.com/~ceckak/pov_people/
----People include file----
Notes: Done but no web page. (can get it from in the zip file of
the two pictures involving them in the gallery page).
Description: Makes people that look like a more advanced version
of Lego figures. Many options for things like race, gender,
clothing, etc.
(*)3.8 -- Starfields
(*)----3DStars.inc----
Author: Jason Widdy -- jwi### [at] lin cbl com au
WWW: http://www.cbl.com.au/~jwiddy/rt.html
http://www.lancs.ac.uk/postgrad/thomasc1/render/utility.htm
Description: Makes a 3D starfield that can be animated. All
within POV-Ray itself.
(*)----Nebula.inc----
(*)----POVRay Star Field Generator
WWW: http://www.geocities.com/SiliconValley/Lakes/1434/otherincludes.html
Description: Also makes a 3D starfield that can be animated. All
(*)----Universe----
Author: Jess Diard -- jes### [at] earthlink net
Version: 1.1
Platform: Win95/NT
Tryout Type: Shareware
Cost: US$19.95
WWW: http://home.earthlink.net/~jessd/universe.htm
Description: This is a preprocessing program for making bitmap
starfields. Has many many options.
3.9 -- Special Object Modifiers
These are utilties which modify objects you've already built
in interesting ways.
----de Jong Box----
Author: Robert Bihlmeyer -- ?
Version: 3.0
WWW: http://www.dhc.net/~swallace/review1.htm#deJong
Description: Takes an object, chops it up, and spins the
pieces around. Also can twist gradients.
Notes: Used to be a C program. Still availible for those
not using POV-Ray 3.
----Object Exploder Include File----
Description: By Author "The Object Exploder Include File allows
you to take any POVRay object and explode it into a mass of
animated particles, simply by specifying the object to explode
along with its size and position." It has MANY options like:
The number, and kind of particles. The strength, and location
of the explosion. Gravity, ground plane, and turbulance can be
added. Whether an object is hollow, or not, etc.
----Spinner.inc----
Author: ?? -- cox### [at] netcom com
Version: ?
Description: By Redbeard "POV Cuisenart for POV-Ray 3.0. It slices
up any object, spins the pieces around the Y axis in definable
steps, and spits out a completed object. (But it doesn't make
julian fries.)"
3.10 -- Misc. Object Generators
----CBraid.inc----
Version: 0.50
Description: From Author "A POVRay 3.0 utility include file that creates
a circular braid. This version now supports individual textures for
each strand, as well as multiple object types (i.e. union, merge, and
blob). It's still rather angular, though."
----Chess2POV----
Author: Brian Mason -- bri### [at] gvn net
Version: 1.0 (August 30, 1996)
Platform: MSDOS
Interface Type: Simple menu system.
Export: POV (2.2)
WWW: http://www.gvn.net/~brian448/chess.htm
Description: Program which takes a text file of a chess match
(using algebraic notation), and creates all the POV-Ray files
needed to make an animation of the entire match.
----Columns----
Author: Nathan O'Brien -- no1### [at] ozemail com au
Version: 1?
WWW: http://www.ozemail.com.au/~no13/
Notes: Columns showing the Five Classical Orders of Architechture.
----The Fabulous chain.inc----
Author: Rob Antonishen -- ran### [at] geocities com
Version: 1,1
WWW: http://www.geocities.com/SoHo/7865/chain.htm
----Fountain----
Author: Jason Mussetter --
Version: 0.40?
Export: Vivid/POV-Ray/Polyray
FTP: NCTUCCCA.edu.tw/Graphics/pov-ray/gen/pc/fount040.zip
Description: A pretty old program which modelled water,
using blobs. Such things as gravity and a ground plane
can be taken into account.
Notes: This is an old beta, and I haven't been able to find
out anything more about the author except that he was
(maybe still is?) a member of The Graphics Alternative BBS.
If anyone knows where to contact him, or any other info.,
please let me know!
----Liquid Spray Include File----
Author: Chris Colefax - cco### [at] geocities com
Version: May 1997
Description: By Author "The Liquid Spray Include File allows you
to create a whole range of particle spray objects, such as
fountains, hoses, waterfalls, and even fireworks!" Also has
things like color changing and mixing, bouncing and puddling
on ground planes, etc.
----Particle-System----
Author: Andreas Hirczy -- ahi### [at] sbox tu-graz ac at
Platform: Code is for Linux, but could be converted if needed.
File Type: Source Code + Script
WWW: http://www.sbox.tu-graz.ac.at/home/ahi/particle-system.html
Description: Is a program that simulates the movement of
water drops. Main program makes the particles, with a PERL
script converts it to POV-Ray blobs.
----Poolball Plugin----
Version: 1?
---Pyramid.inc----
Version: 1.0
Description: From Author "Generate a variety of multi-sided pyramids
using various different methods of specifying the size of the pyramid.
These include specifying the length of a base edge, the height, the
angle of the sides, the radius of a circle circumscribed about the
base, etc."
----Pyr_cube.inc----
Version: 1.0
---POVGraph----
Author: Daniel Boesswetter
Maybe: Dan### [at] informatik tu-muenchen de ??
(must look in archive)
Platform: DOS/Win95 (must find new page location for Win95)
WWW: http://www.dhc.net/~swallace/review1.htm#povgraph
Gone: http://firewall.fh-rosenheim.de:8888/~boewe/welcome.html
----Sparks----
WWW: http://www.dhc.net/~swallace/review1.htm#spark
----Spiral.inc----
Author: Felix Morley Finch -- fel### [at] crowfix com
Modifications By: Michael D Johnson -- mdj### [at] voyager net
Version: 1.0
Descripton: Utility to create spiral staircases.
----Stwist.inc----
Version: 1.0
Description: By Author "A POVRay 3.0 utility to create candy cane / pretzel
twists, and other interesting twisted things."
(#)----3D House----
Author: Richard A. King
Version: ?
Platform: ?
WWW: http://www3.sk.sympatico.ca/kingh/u_design.htm
Older-> http://www.sasknet.com/users/kingh/html/u_design.htm
Notes: Info. is pretty sketchy at the site. I'll have to email
the author for more info. on this program, or d/l some of
the stuff in the d/l directory.
----TorPatch----
Author: Mark Mackey -- mdm### [at] cus cam ac uk
Nathan Beddes -- Nat### [at] m cc utah edu (C Conversion)
Version: ?
Tryout Type: Freeware (GNU GPL)
Source Code: Yes (C and Turbo Pascal)
WWW: http://www.ch.cam.ac.uk/MMRG/torpatch.html
Description: From Author "Given a series of points in space, Torpatch
joins them smoothly with sections of tori. As a basic function
Torpatch can output the coordinates of a torus section passing through
any three points, or through two points given a tangent at one of
them. The torus section can be extended to pass smoothly through any
other set of points. Torpatch can also generate random 'tangles' if
so desired."
----ShellyLib----
Author: Randolf Schultz -- rsc### [at] informatik uni-rostock de
Version: 2.0
Platform: Binaries for Win3.x and Amiga
Cost: $30 commercial -- $15 non comm. -- $10 academic
Export: RPL/DXF/T3D/NFF/OFF/POV/LOBJ/RAY/VORT/X3D/TSP/SCED/RIB
Source Code: Yes (C)
WWW: http://www.informatik.uni-rostock.de/~rschultz/shellylh.html
Notes: Tcl/Tc, Mesa 3D, and Togl needed for unix.
4 -- Animation
----AERO----
Authors: Hartmut Keller -- kel### [at] informatik uni-stuttgart de
Horst Stolz -- sto### [at] isa de
Thomas Bräunl -- bra### [at] informatik uni-stuttgart de
Version: 1.7.0
Platform: Linux/DECstation 5000/Iris4D/SunOS4.1.x/Solaris2.x
Source: Yes (German comments--being translated)
WWW: http://www.informatik.uni-stuttgart.de/ipvr/bv/aero/
FTP: ftp.informatik.uni-stuttgart.de/pub/AERO/
----Anim8----
Author: Mark Willis -- maw### [at] mindspring com
Version: 1.4
Platform: MSDOS/Windows(in dos box)
Tryout Type: Shareware (nag screens)
Cost: $10
Export: Any text-based raytracer (Povray, Polyray, Vivid, etc)
WWW: http://www.mindspring.com/~maw01/skinz/skinz.htm
----Basic Dynamic Motions----
Author: Hideki Komuro -- kom### [at] super win or jp
Version: 0.50 (January 10, 1997)
File Type: Include Files
WWW: http://www.win.or.jp/~a-kojima/indexe.html
Description: A series of include files that let you do
an animation of an object bouncing on the floor, bouncing
or rolling down stairs, and of two waves crashing into
each other. Many options for each file.
----Basic Scene Example [For Walking.inc (Wilbot)]----
Author: Theresa Willis -- twi### [at] sound net
Version: November 8, 1996
WWW: http://www.10mb.com/jbarchuk/twillis/
Note: There are 2 different versions of the file. One web
site having one, and the other having the second. The
only difference between them is that the one from the first
address has a .FLC file of the finished animation.
Description: An example file for Walking.inc include file.
----Campath----
Author: John Hammerton -- CIS: 71320,3147
Version: 1.1a
Platform: MSDOS
Source Code: Older version does, but newer one doesn't.
WWW: http://www.dhc.net/~swallace/review3.htm
----D/Animator----
Author: Dexter Kofa? DexTechnologies?
WWW: http://dept.physics.upenn.edu/~www//gladney/dex/Freebee.html
Notes: Can't find new home pages. I know at one point it moved to
http://vision.sas.upenn.edu/dextech.html
but I can never connect to that site.
These sites seem to be somewhat related:
http://tonetmedia.com/dex/
http://www.netaxs.com/~legend/geosync/direct.html
http://vision.hep.upenn.edu/
http://www.tech-9.com/uplift.html
If anyone can track down the new site, I'd really appreciate it.
----Dave G's Animation System----
Author: David Govoni -- dav### [at] sympatico ca
Version: 0.95a (March 31, 1997)
WWW: http://www.geocities.com/SiliconValley/Vista/3378/new.html
Description: By Author "DGAS is a series of include files for POV-Ray.
It allows you to easily include advanced animation techniques in
your pov file. The include files are broken into three main groups:
Dave G's Particle Animation System
Create Particles that appear and dissappear
Move, accelerate, or even bounce them
Dave G's Bezier Curve System and Dave G's Multiple Curve System
Create simple bezier curves
Create 'exact' bezier curves
String curves together into paths.
Dave G's TimeLine System
Break an animation into segments of various durations"
----Motion Control System (MCS)----
Author: John Kolesar -- jko### [at] ix netcom com
Version: 1.0 (7/5/95)
Platform: Win3.1+
Notes: Needs VBRUN300.DLL to run.
Description: In this program, you make a special script, with options
for various things like moving, spinning, etc. Then, it uses this
to make multiple included files (which can be zipped automatically).
These include files are renamed as the files are rendered, so that
only one #include must be put in your POV file. While its default
motions can be started an stopped at various frames, the feature that
is probably more powerful in many cases, is its ability to have
multiple generic Count variables (instead of just one in POV-Ray 3).
There is also a feature to make objects you specify explode.
----Patrick's Curve Generator (PCG)----
Author: Patrick LeBlanc -- 6pg### [at] qlink queensu ca
Version 2.21
Platform: Win3.1(with win32s)--Win95--Maybe NT?--Linux
Tryout Type: Postcardware (?)
Cost: I have to d/l it, but probably a post card?
WWW: http://qlink.queensu.ca/~6pgl/programs.html
Notes: This program makes win32 system calls, but is a command-
line only program. Linux users should d/l windows archive to
get example files.
Description: By Author "V2.21 is an animation tool for Povray 3 that
not only allows the animator to precisely and VERY easily control
the movement of objects smoothly through space and time, but
permits the fine control of object scale, color, velocity, or
intensity in the case of light sources." Uses cubic spline
interpolation in a generic way so that the above things are only
examples. Works with POV-Ray 3's animation loop.
----PovACT----
Author: Aaron Singline -- a.j### [at] xtra co nz
Version: 1.0
Platform: MSDOS
WWW: http://www.geocities.com/ResearchTriangle/1641/raylnk.htm
Descripton: The "Povray Animation Creation Tool" A simple
animation utility to help you animate the position and lookat
vector of the camera, and the postion, rotation, and scaling
of an object. You specify the # of frames, and the starting
and ending vector for each atribute. Then it makes a batch
file to do it. The animation corrlates to tags you put in
a .pov file.
Notes: The program in its current stage, while helpfull for
POV-Ray 2.x, is of limited use for POV-Ray 3. It is also
less flexible than many of the other animation tools.
----POVAni----
Author: Luis G galvez -- lug### [at] ix netcom com
Version: 1.0 (December 31, 1996)
Platform: Win3.1--Win95
Cost: $20
Description: This program works by using special keywords in your
POV-Ray scene file. There are options for linear, sin, pulse,
random, and more. The program file then calls POV-Ray for dos,
and renders the TGA files. A special text editor to help with
inserting the functions is included, as are a couple of examples.
----PovRay AnimSystem----
Author: Fran ? -- ffi### [at] ihug co nz
Version: ?
File Type: I think Include Files?
WWW: http://www.geocities.com/SiliconValley/Pines/8549/animsys.htm
----PovTick----
Version: 2.0
Platform: MSDOS/Windows(in DOS box)
Export: Any text-based raytracer?
Notes: PovTic is the predecessor to Anim8
----Son of Wilbot----
Version: March 19, 1997
Description: This is a more advanced version of walking.inc
aka Wilbot. You create files for each character in the scene,
defining things like proportions of body parts, and how they
can rotate during animation. Then you can add more than one
of these characters to a scene and let them go.
----Varmint's POV Animator----
Author: Eric Jorgensen -- var### [at] itsnet com
Version: 1.0
Platform: MSDOS
WWW: http://www.itsnet.com/~varmint/html/vpova.htm
FTP: ftp.itsnet.com/pub/varmint/vpova10.zip
Notes: Includes source code (Turbo C).
----Walking.inc (Wilbot)----
Version: October 24, 1996
Description: This is an include file for making a walking
humanoid (looks like a robot if you keep the default
objects). It has options for body proportions, and
animation attributes like length of stride, speed, etc.
By Shawn Fumo
sha### [at] the-spa com
http://www.the-spa.com/shawn.fumo/
