POV-Ray : Newsgroups : povray.binaries.utilities : Exporting tools : Re: Exporting tools Server Time
24 Mar 2026 21:03:33 EDT (-0400)
  Re: Exporting tools
Date: 4 Mar 2023 19:45:00
Message: <web.6403e54e26764c41a30d213ddabc9342@news.povray.org>
yesbird <sya### [at] gmailcom> wrote:
> On 05/03/2023 01:34, Mike Miller wrote:
> Hi, Mike.
> > Thank you YB! I'll definitely check that out. Love to see how you're handling
> > the data. I'm doing something similar with dxf ascii files exported from Cad.
> > Have you looked at Blender? - I've use it for FBX exports for odds and ends. Not
> > sure if vertex color can be preserved but individual objects/spheres would carry
> > a material name that could be used in a macro.
> I should say that I started to write a C4D exporter after looking at
> your workflow - POV definitely needs some external drawing tools. I used
> AutoCad 10 in 1993, writing extensions for
> ecological calculations (insolations and noise normatives in
> architecture), now C4D is my first 3D tool. Exporter is almost
> completed, I'm doing final cleanup now and hope tomorrow will be the
> first release :)
> > Attached is my latest fish model floating around some pipes from a chemical
> > spill.  ...we just had a chemical spill over into Ohio..haha.
> Horror ...
> > It started as an underwater scene, but I added a reflection pool so I'm not sure
where this is
> > going. It's a work in progress but I like the rendering so far - so I'm posting
> > it.
> Rendering is really good, and also I like to look at the development
> process in dynamics, including basic drafts, this gives me an idea of
> the author's thinking methods.
> Looking forward for your new posts.
> YB
Thanks YB,
you started using AutoCAD before I did. :)
I bought 3DS Max in 93 and stared using AutoCAD 12 professionally in '95 or so.
Below is the pipe macro for the fish scene I just posted. Almost a parametric
object. :)
//--- pipe and flange parts
//--- miller 3.2.23
#include "shapes3.inc"
#macro pm_lathe_pipe (w,h)
    lathe{
        linear_spline
        4,
        <0, 0>,
        <0, h>,
        <w, h>,
        <w, 0>
#declare fill_object  = 1;
#declare merge_object = 1;
#declare pipe_height = 5;
#declare pipe_rad = 1;
#declare flange_height = 4.7;
#declare flange_rad = 2;
#declare edge_rad = .05;
#declare double_flange = 1;
#declare flange_collar = true;
#declare collar_height = .5;
#declare collar_rad = pipe_rad + .1;
#declare bolt_count = 8;
#declare bolt_sides = 6;
#declare bolt_rad = .25;
#declare bolt_height = .25;
#declare bolt_position = <pipe_rad + ((flange_rad-pipe_rad)/2),
flange_height-bolt_height, 0>  ;
#declare pipe_ribs = 3;
#declare pipe_rib_rad = .05;
//--- bolt prototype
#declare bolt =
Round_Pyramid_N_in(
    bolt_sides,
    <0,0,0>,
    bolt_rad,
    <0,bolt_height,0>,
    bolt_rad,
    edge_rad,
    fill_object,
    merge_object )
#declare bolt_end =
Round_Pyramid_N_in(
    bolt_sides,
    <0,0,0>,
    pipe_rad*.6,
    <0,-.25,0>,
    pipe_rad*.55,
    edge_rad,
    fill_object,
    merge_object )
#macro pipe_with_flange()
union{
    Round_Cylinder_Tube(
        <0,0,0>,
        <0,pipe_height,0>,
        pipe_rad,
        edge_rad,
        fill_object,
        merge_object )  //-- main vertical pipe
        <0,flange_height,0>,
        <0,pipe_height,0>,
        flange_rad,
        edge_rad,
        fill_object,
        merge_object )  //--- top flange
    #if (double_flange = 1)
            <0,pipe_height,0>,
            <0,pipe_height + (pipe_height-flange_height),0>,
            flange_rad,
            edge_rad,
            fill_object,
            merge_object )  //--- double flange
            #if (bolt_count > 0)
                #declare c=0;
                #declare inc=360/bolt_count;
                #while (c < bolt_count)
                    #declare r_y = inc*c;
                    #declare n_x = bolt_position.x ;
                    #declare n_y = bolt_position.y +
(pipe_height-flange_height)*2 + bolt_height;
                    #declare n_z = bolt_position.z ;
                    object {bolt translate <n_x, n_y, n_z> rotate y*r_y}
                    #declare c = c + 1;
    bolt_end
        #declare c=0;
            #declare new_y = inc*c;
            object {bolt translate bolt_position rotate y*new_y}
            #declare c = c + 1;
    #if (pipe_ribs> 0)
        #declare c=0;
        #declare inc=flange_height/pipe_ribs;
        #while (c < pipe_ribs)
            torus { pipe_rad ,pipe_rib_rad translate <0,new_y,0>}
            #declare c = c + 1;
    #if (flange_collar = true)
        #declare n_y = (pipe_height -(pipe_height-flange_height)) -
collar_height ;
            <0,n_y,0>,
            <0,n_y + collar_height ,0>,
            collar_rad,
            edge_rad,
            fill_object,
            merge_object )  //-- collar
//object { pipe_with_flange() material{some_material} scale .2 }
