POV-Ray : Newsgroups : povray.binaries.utilities : Wood design program test version : Re: Wood design program test version Server Time
20 Mar 2026 20:33:00 EDT (-0400)
Date: 13 Jul 2022 03:20:00
Message: <web.62ce71f44b788a989ac997d1aa81652d@news.povray.org>
"jr" <cre### [at] gmailcom> wrote:
> hi,
> (it is a day for "bugs", it seems :-))
> "And" <49341109@ntnu.edu.tw> wrote:
> > Thomas de Groot <tho### [at] degrootorg> wrote:
> > > Next, I shall try to give my views/ideas on the layout, comprehensive
> > > use, etc, of the application.
> tells me it works on MS Windows, but not (for me) on Linux (like 'rtr' </sigh>).
> after exiting the program and changing into the 'example1' directory, POV-Ray
> does not like the spaces in the file name, so when:
>   $ povparse +i"show tree function.pov"
> Problem with option setting
> /usr/local/bin/povray-3.8.0-beta.2 +w32 +h32 -d -f -p -gr -gs +ishow tree
> function.pov
> Failed to parse command-line option
> another error occurs because the 'pretrace_*' settings depend on image size, eg
> with the (small) WxH settings above.
> however, file renamed and using a large enough WxH, I get another error.  not
> even sure what the problem is supposed to be (since the code looks kosher (to
> the untutored eye)):
> File 'functions.inc' line 9: Parse Warning: Scene language version changed after
>  a 'default' statement. The changes in defaults normally associated with the
>  language version change are not applied.
> File 'example1_angular_shape_factor.inc' line 10: Possible Parse Error:
>  Suspicious identifier found in function! If you want to call a function make
>  sure the function you call has been declared. If you call an internal function,
>  make sure you have included 'functions.inc'.
> File 'example1_angular_shape_factor.inc' line 10: Parse Error: Expected
>  'operator', ( found instead
> Fatal error in parser: Cannot parse input.
> Render failed
> regards, jr.
Thanks.
It should copy some text but it didn't.
(I should use \ not // for the file path connect)
I fix it and attach a new version.
No any other change, besides adding axis on the angular-shape-editor for
identify the direction.
Download 'wooddesignprogram alpha ver20220713.zip' (982 KB)
