POV-Ray : Newsgroups : povray.binaries.utilities : Wood design program test version : Re: Wood design program test version Server Time
4 Jul 2025 05:58:55 EDT (-0400)
Date: 5 Jul 2022 03:55:00
Message: <web.62c3ee104b788a98d75d356baa81652d@news.povray.org>
> Exactly. The issue here is whether the 'comma' represents a 'Thousands
> separator' (example: 3,943,200.00) or - and I guess this is what is
> intended here - the 'decimal dot' (example: 3943200,00). Neither can be
> used by POV-Ray.
> As far as I understand this issue, the use of 'thousands separators' is
> only a visually attractive(?) trick, while calculations on those numbers
> ignore them (obviously). My advice would be to drop them altogether,
> especially for input to POV-Ray.
> Thomas
What the length unit does you use? Because my outputting number is usually small
with this program(while meter is the length unit).
