POV-Ray : Newsgroups : povray.binaries.utilities : Wood design program test version : Re: Wood design program test version Server Time
1 Apr 2026 02:06:38 EDT (-0400)
Date: 4 Jul 2022 12:30:00
Message: <web.62c314a84b788a98f10dbcecaa81652d@news.povray.org>
> Op 27-6-2022 om 17:56 schreef And:
> > First release.
> Thanks And!
> Test version, so I shall not (yet) comment on the visual aspects and so on.
Thanks for understanding.
> However, one very important thing is the way decimals are written to the
> example include files. My system uses 'dots' (example: 3.9432) instead
> of 'commas' (example: 3,9432) like is done by your app. I guess that
> some countries/systems do so standard, but not all.
I use 'meter' as the length unit, so that output result is caused by my habit.
The dots are decimal points.
I want to ask a question, a number contain commas can be read as 'one' number
correct by POV-Ray?
Can 3,9432 be a number?
> If this is an issue for better international use, could you make
> this an initial choice to make by the user? Or is there another way to
> change this easily?
> Thomas
Currently You might need use 'scale' to the pigment to convert it to your
customary unit. I will add a list(menu) to select unit on the "Basic
Profile"(first page) in the future version. But I need time to research this.
