POV-Ray : Newsgroups : povray.binaries.utilities : Wood design program test version : Re: Wood design program test version Server Time
23 Mar 2026 10:04:39 EDT (-0400)
Date: 28 Jun 2022 04:35:00
Message: <web.62babc354b788a98fa45e687aa81652d@news.povray.org>
"Edit Angular Shape" can change the shape of the woodgrain. It use polar
coordinate. In fact it control a series of value(default value = 1). When you
drag a control node to make a larger radius, it make the value > 1; when you
drag a control node to make a smaller radius, it make the value < 1.
These three curves located at r = 0.266..m, r = 0.533..m, r = 0.8m.
This is an approximate method. The output result should be accurate when you
just adjust the shape slightly. But if you distort the shape overly the result
will be unpredictable.
Download 'gui edit angular shape.png' (118 KB)
Preview of image 'gui edit angular shape.png'
