POV-Ray : Newsgroups : povray.binaries.utilities : Polynomial Spreadsheet : Re: Polynomial Spreadsheet Server Time
7 Apr 2026 14:20:46 EDT (-0400)
Date: 24 Oct 2017 20:25:00
Message: <web.59efd8cb63d226a55cafe28e0@news.povray.org>
"B. Gimeno" <nomail@nomail> wrote:
According to the documentation, the
> polynomial version of the syntax lacks the "command" parameter at first so that
> the program starts processing.
I checked out the results using the data for the torus in the docs, and I think
I see what you mean.  polynomial {} requires the order of the equation followed
by the rest of the data.  I made the edit, and it should work fine now. [version
1.0a]
> From the "function" version I lack experience to
> know why it also gets stuck in the calculation. Greetings, and thank you for
> sharing.
> B. Gimeno
I'm not sure what you mean by "stuck" - does POV-Ray give you an error?
I had no problems when I copied and pasted the function into a scene:
#declare Polynomial = function {(pow(x,4)) + (2 * pow(x,2) * pow(y,2)) + (2 *
pow(x,2) * pow(z,2)) + (-104 * pow(x,2)) + (pow(y,4)) + (2 * pow(y,2) *
pow(z,2)) + (56 * pow(y,2)) + (pow(z,4)) + (-104 * pow(z,2)) + 784}
and then used that function in an isosurface:
isosurface {
 function {Polynomial (x, y, z)}
 accuracy 0.001
 max_gradient 4510
  contained_by {box {<-10, -4, -10>, <10, 4, 10>} }
  texture {pigment {DocPigment} finish {specular 0.2}}
} // end isosurface
I may see if I can work out some more refinements to make it a little easier to
use.  I could highlight the terms that need values (if they are non-zero) so
that it's easier to find the terms to edit.  There might also be a way for me to
consolidate the list of terms depending on the order - but that might take quite
a bit of tinkering.
Download 'polynomial 1.0a.ods.dat' (47 KB)
