POV-Ray : Newsgroups : povray.binaries.utilities : Wood design program test version : Re: Wood design program test version Server Time
13 Mar 2026 20:44:12 EDT (-0400)
Date: 5 Jul 2022 02:37:36
Message: <62c3dc30$1@news.povray.org>
Op 04/07/2022 om 20:53 schreef Bald Eagle:
> "And" <49341109@ntnu.edu.tw> wrote:
>>> However, one very important thing is the way decimals are written to the
>>> example include files. My system uses 'dots' (example: 3.9432) instead
>>> of 'commas' (example: 3,9432) like is done by your app. I guess that
>>> some countries/systems do so standard, but not all.
>> I use 'meter' as the length unit, so that output result is caused by my habit.
>> The dots are decimal points.
> Units don't appear to be the issue.   The representation of decimal fractions is
> what Thomas is concerned about.
Exactly. The issue here is whether the 'comma' represents a 'Thousands
separator' (example: 3,943,200.00) or - and I guess this is what is
intended here - the 'decimal dot' (example: 3943200,00). Neither can be
used by POV-Ray.
>> I want to ask a question, a number contain commas can be read as 'one' number
>> correct by POV-Ray?
>> Can 3,9432 be a number?
> Nope.  That would be a string.  AFAIK, all versions of POV-Ray use only numerals
> and the "+,-, and ." glyphs to represent numerical values.  Formatting those
> values using str and probably a macro would be necessary to show the usual
> commas between every step of 10^3.
>>> If this is an issue for better international use, could you make
>>> this an initial choice to make by the user? Or is there another way to
>>> change this easily?
>>> Thomas
>> Currently You might need use 'scale' to the pigment to convert it to your
>> customary unit. I will add a list(menu) to select unit on the "Basic
>> Profile"(first page) in the future version. But I need time to research this.
> I think he means "Is there a way to specify whether to use "," or "." for the
> data's output format.
As far as I understand this issue, the use of 'thousands separators' is
only a visually attractive(?) trick, while calculations on those numbers
ignore them (obviously). My advice would be to drop them altogether,
especially for input to POV-Ray.
