POV-Ray : Newsgroups : povray.binaries.utilities : Domenator, last version : Re: Domenator, last version Server Time
15 Oct 2026 20:08:45 EDT (-0400)
Date: 31 Aug 2021 04:52:29
Message: <612dedcd$1@news.povray.org>
Op 31-8-2021 om 09:37 schreef Mediat:
> Hi Kenneth
> I hope you'll succeed, Thomas has explained the problem and there is nothing I
> can do.
> Enjoy
> Hi Thomas,
> The STL and OBJ Button generate name.STL and name.OBJ files whiche you can read
> in a lot of 3d-viewer (I use glc-viewer), and it should be compatible with 3D
> printers (but I don't have access to any, so I haven't tried)
> The INC button generates the POV file, these 3 files are generated in the
> directory above the one where the exe stands (maybe not a very good idea)
Ah! OK. Confusing indeed, especially as the *.DOM file goes into the
same directory as the exe.
Also, saved *.DOM files when loaded again, do not show the originally
saved object, but a default half sphere.
> If you don't declare any material, you will have to declare one in your pov-file
> for the entire union, but you can be more specific :
I am confused about the 'Materials'(and the objects). Do I have to use
the same names as those given in the droplist for WireFrame/Flat Faces/
Smooth Faces? Whether I do that or not, no materials are exported, nor
is the geometry subdivided according to different materials. In Poseray,
I get one unnamed_group (a half sphere) with one unnamed_material
(white), whatever I do.
> 1) Dome material is the same as the pov definition for the entire object
> 2) Face material will affect the mesh part only
> 3) Struts materials, you can define different material for parallel an meridian
> struts, major and minor struts
> 4) Diagonal struts, same thing for the diagonals (usually you don't want to see
> them, but I have an exemple ...)
> 5) Spheres material, usually the same as one of the struts tha the sphere
> completes
Hmmm... I am unable to reproduce this...
> In the image trashbin, the faces are not generated, only the major parallele
> struts have a non 0 radius
> In the franc-contois image (it is a dome I saw in a french xountryside called
> lead material.
Nice ones!
