POV-Ray : Newsgroups : povray.binaries.utilities : export blender's smoke : Re: export blender's smoke Server Time
18 Mar 2026 15:42:15 EDT (-0400)
Date: 20 Mar 2018 01:45:51
Message: <5ab0a00f$1@news.povray.org>
On 20/03/2018 03:26, And wrote:
> Stephen <mca### [at] aolcom> wrote:
>> On 19/03/2018 14:21, And wrote:
>>> "And" <49341109@ntnu.edu.tw> wrote:
>>>> I want to export smoke of blender. I wrote some code to read df3, and here
>>>> https://wiki.blender.org/index.php/Extensions:2.6/Py/Scripts/Render/POV-Ray
>>>> it says "A DF3 file (POV-Ray voxel format) is exported. I want to know where is
>>>> this file.
>>> I have tried render a scene from it.
>> I hope I can explain this.
>> In Blender with the render set to PovRay. Go to the scene properties
>> (camera icon). Open the "Output" property and you will see the o/p
>> directory. Mine reads /tmp/ Click the folder icon and Blender will show
>> you where the Pov file should be saved.
>> I've not tried using df3s myself. Although I found and reported a bug
>> using boids.
>> Keep us informed on how it goes.
>> Regards
>>       Stephen
> Hmm I tried change the output directory to D:\ but it doesn't save the files to
> that. I found the .pov and output image on user\AppData\Local\Temp directory
> where PovRay message shows. Opening the .pov I found the df3 path finally. It is
> on
> ....user\AppData\Roaming\Blender Foundation\Blender\2.79\preview\smoke.df3"
> Windows 7.
> Thanks for the response.
Sorry, I did some checking and that o/p location is for the render o/p.
My pov files are saved in the same location that the blend file is saved in.
I do have some files in %appdata%\Blender Foundation\Blender\2.79\preview
But they are associated with a file that had packed textures. I don't
know what happened there.
Regards
