POV-Ray : Newsgroups : povray.binaries.tutorials : POV-Ray Voodoo #511: Radiosity brightness setting Server Time
11 May 2025 21:41:33 EDT (-0400)
  POV-Ray Voodoo #511: Radiosity brightness setting (Message 1 to 1 of 1)
Subject: POV-Ray Voodoo #511: Radiosity brightness setting
Date: 22 Nov 2009 09:11:53
Message: <4b0946a9@news.povray.org>
For all those who - just like me - have wondered what the most realistic
setting for the radiosity "brightness" parameter should be:
After having done some experimenting and comparison with MCPov (see
povray.unofficial.patches), I can conclude with confidence:
   "brightness 1.0" is absolutely right.
With "recursion_limit 1", it may even make sense to increase the
brightness a bit above 1.0, to compensate for the "missing" multi-bounce
diffuse illumination.
Any dissimilarities with MCPov results are pretty likely due to an error
in MCPov (which gets the brightness wrong by a factor of 2), and any
overly bright materials are pretty likely to be due to gamma issues, bad
material settings, or inferior lighting setup. Or possibly even other
bugs in conjunction with radiosity - but the default brightness value is
absolutely right.
