POV-Ray : Newsgroups : povray.binaries.tutorials : Check(er) Your Gamma : Re: Check(er) Your Gamma Server Time
28 Nov 2026 03:39:14 EST (-0500)
Date: 4 Nov 2009 23:58:17
Message: <4af25b69$1@news.povray.org>
SharkD schrieb:
> The instructions for adjusting your display settings are already in the
> docs, aren't they?
If you're referring to setting up POV-Ray, then yes: The POV-Ray 3.6
instructions how to identify the proper Display_Gamma setting for your
system are still valid for 3.7.
If you're referring to setting up your image viewer / operating system /
  graphics driver / display hardware, you will have to check out the
respective manuals and/or them interwebs.
Usually your graphics card will have come with /some/ tool to check and
adjust your display gamma to whatever the operating system typically
expects, and most image viewers will rely on the operating system and
drivers for converting from the OS' standard gamma to the display
hardware gamma.
On a properly calibrated Windows PC, following the instructions to set
up your Display_Gamma should usually give you a setting of 2.2.
