POV-Ray : Newsgroups : povray.binaries.tutorials : Check(er) Your Gamma : Check(er) Your Gamma Server Time
21 Mar 2026 01:42:17 EDT (-0400)
Date: 3 Nov 2009 23:25:53
Message: <4af10251$1@news.povray.org>
You know your gamma settings are wrong if...
... you see a chrome sphere on a /checkered/ plane (even if you squint
your eyes or look from a distance) in this image/scene.
Ideally, the plane should appear in a featureless uniform grey (except
for some moiree effects near the horizon and maybe in the reflection).
If instead it appears to show squares of alternating shades of grey,
something's bogus:
(A) If you see checkering in the attached image file, then your image
viewing software / operating system / graphics drivers / display
hardware is poorly calibrated, and you should fix it before proceeding.
(B) If (after fixing (A)) you see checkering in the preview window
and/or the output file when rendering the scene file below, then your
Display_Gamma (POV-Ray 3.6 and 3.7) and/or File_Gamma setting (POV-Ray
3.7 only), respectively, is wrong.
// +w640 +h480 +a0.3
global_settings { #if (version < 3.7) assumed_gamma 1.0 #end }
#local CameraPos   = <0.0,0.0,-4.0>;
#local CameraDepth = 1.0;
#local CameraTilt  = 5;
   location  <0,0,0>
   direction z*CameraDepth
   up        y
   translate CameraPos
   rotate    x*CameraTilt
sky_sphere {
     gradient y
     color_map {
       [0.0 rgb <0.6,0.7,1.0>]
       [0.7 rgb <0.0,0.1,0.8>]
light_source {
   <-30,30,-30>
   color rgb 1
   parallel
#declare Ratio = image_height*CameraDepth;
#declare FnScanlines = function { abs(mod(abs(Ratio*y/z+0.5),2.0)-1.0) }
plane {
   y, -1
     checker
     pigment { color rgb 0.5 }
       function { FnScanlines(x,y,z) }
       color_map {
         [0.0 color rgb 0.0 ]
         [0.5 color rgb 0.0 ]
         [0.5 color rgb 1.0 ]
         [1.0 color rgb 1.0 ]
       translate CameraPos
       rotate x*CameraTilt
       rotate y*-30
       scale 1/3
     scale 3
     rotate y*30
sphere {
   0, 1
   pigment { color rgb 1 }
   finish { ambient 0 diffuse 0 reflection { 1 } }
