POV-Ray : Newsgroups : povray.binaries.scene-files : PROOF : core include files and test code. Server Time
31 Jan 2025 07:05:35 EST (-0500)
  PROOF : core include files and test code. (Message 1 to 10 of 15)
Subject: PROOF : core include files and test code.
Date: 2 Mar 2022 05:15:00
Message: <web.621f42cb592fe9587283012224d82e4@news.povray.org>
Here is a zip containing PROOF's core include files and a basic test code file.
Contents:
primitives.inc : basic definitions (some could be part of POV-Sdl native syntax)
oocore.inc : object oriented core features, definitions, macros, etc ...
oocore_test.inc : test code for oocore.inc. The result is text in #debug
channel.
oocore_test.pov : scene file for oocore_test.inc. The appearance of the
                  ready made basic scene means all went OK.
                  ==> Run the "oocore_test.pov" file and see the #debug channel
(Messages tab) for the results.
Remember, it is just an WIP for an early POC.
I consider that the main OO features are available and oocore.inc makes the job.
Therefore, I had a go for objects in scene and designed classes in order to
describe spheres, boxes, cylinder, toruses, and (in the future) all POV's
objects by PROOF's classes, including voluminous objects (mesh, mesh2, blob,
complex CSG's...) for which we will be in position to control the behaviour.
REMARKS:
Rem1: splines can be described by classes and be easily controlled because
instances keep track of internal data (spline defining points in this case). We
can extend, catenate, normalize, .... in a clean and easy manner. Splines are in
my TODO list.
Rem2 : Trees are complex structures that can be embeded in classes.
Rem3 : Animation could be eased with an object-oriented approach
Rem4 : I think that if I could write Sdl code for OO, then the parser can do it
natively with the appropriate evolutions.
Regards
Bruno
Download 'proof_core_wip1.zip' (9 KB)
Subject: Re: PROOF : core include files and test code.
Date: 2 Mar 2022 12:55:00
Message: <web.621faeea26e475b0ed36e5cb6cde94f1@news.povray.org>
hi,
quick.  :-)  thanks, will find some time to look at week's end.
fwiw, here's a (quad)tree in SDL:
<https://news.povray.org/povray.binaries.images/message/%3Cweb.5eeb464b936ed80b4d00143e0%40news.povray.org%3E/#%3Cweb.5
eeb464b936ed80b4d00143e0%40news.povray.org%3E>
regards, jr.
Date: 4 Mar 2022 10:05:00
Message: <web.622229a126e475b0ed36e5cb6cde94f1@news.povray.org>
hi,
> Contents:
oops..  ;-)
Persistence of Vision(tm) Ray Tracer Version 3.8.0-alpha.9945627.unofficial
==== [Parsing...] ==========================================================
File 'oocore.inc' line 35: Possible Parse Error: Cannot find file
 'collections.inc', even after trying to append file type extension.
File 'oocore.inc' line 35: Parse Error: Cannot open include file
 collections.inc.
Fatal error in parser: Cannot parse input.
Render failed
regards, jr.
Date: 6 Mar 2022 12:30:00
Message: <web.6224eead26e475b07283012224d82e4@news.povray.org>
"jr" <cre### [at] gmailcom> wrote:
> hi,
> > Contents:
> oops..  ;-)
>  collections.inc.
> Render failed
> regards, jr.
Yes, ooops :)
So sorry. However, "collections.inc" is not required for "oocore.inc" and
"oocore_test.inc" ... You can comment the #include statements.
B.
Date: 6 Mar 2022 16:45:00
Message: <web.62252a4526e475b0ed36e5cb6cde94f1@news.povray.org>
hi,
thanks, that did it.  will defer comment(s) until I've seen a more functional
example, other than to say that re yr comment about finding a way to test
whether the argument is a function (for 'primitives.inc:check'), have a look at
WFP's 'povr' and the 'setidtypes.inc' mechanism.
regards, jr.
Date: 7 Mar 2022 13:30:00
Message: <web.62264e2e26e475b07283012224d82e4@news.povray.org>
> hi,
> regards, jr.
Thanks!! Will post new version of "primitives.inc" and "collections.inc" with
unit
testing code. Then, I will do some unit testing with "oocore.inc". And then, I
will expose my "objects.inc", the one that deals with scene objects,their core
class hierachy and fundamental mechanisms.
Bruno
Date: 8 Mar 2022 04:37:09
Message: <622723c5@news.povray.org>
>> hi,
>> regards, jr.
> unit
> Bruno
Hi folks!
Please find hereafter new versions of "primitives.inc" and
"collections.in" with unit-testing code.
Working on unit-testing "oocore.inc", the core Object Oriented features.
Then will come "objects.inc" and its unit-testing file(s).
Regards
     Bruno
L'absence de virus dans ce courrier électronique a été vérifiée par le logiciel
antivirus Avast.
https://www.avast.com/antivirus
Download 'collections_ut.pov.txt' (11 KB) Download 'primitive_ut.pov.txt' (16 KB) Download 'primitives.inc.txt' (10 KB) Download 'collections.inc.txt' (11 KB)
Date: 10 Mar 2022 11:00:00
Message: <web.622a1f9026e475b0ed36e5cb6cde94f1@news.povray.org>
hi,
great, something for the weekend :-).
regards, jr.
Date: 14 Mar 2022 12:40:00
Message: <web.622f6dcb26e475b0fc0c8de6cde94f1@news.povray.org>
hi,
> Hi folks!
have had a look around, some nice ideas there, genuinely looking forward to
seeing where, application-wise, your efforts will lead.  while the following
will probably read like "critique", it's not really, just highlighting
(potential) issues, and yes, adding a "gripe" or two :-).
names.  collections.inc:234:"// Could not use 'slice' as it is a SDL keyword".
so why not 'Slice' (not that I'm advocating uppercase use :-)) or '_slice'?  the
problem, imo, is not the keyword per se, but your use of names like 'get()' for
"globally visible"s, ie no "namespacing".  the "obvious" choice would be 'oo'
followed by underscore or camelcase.  (macro names used unadorned include:
check, exec, exists, extend, get, in, list, map, next.  sure, not keywords, but
common perhaps?)
if I understand the code correctly, in 'primitives.inc' you use the 'rgb'
keyword to coerce values to 3-vector format?  would '<1,1,1>*value' not do the
same, "cleaner"?
extend() - not sure how far you will be able to .. bend SDL :-), but think that
an important macro like extend should be "general".  clipka's advice wrt arrays
was (paraphrasing) "if you know the #elements in advance, declare the array
sized"; however, if I were to:
  #declare A = array [2] {"a","b"};
  #declare B = array [2] {"c","d"};
  extend(A,B)
I'd get: "Parse Error: Array subscript out of range".
gripe(s): why does yr editor not always place whitespace between keyword and
brace?  personally also not a friend of long lines, particularly when concluded
by C++ style comment(s).  including another include (colours) for just white +
yellow?  (also makes the versioning more "dependent")  tja, and then there's the
unit test output.. :-)  without any documentation for yr project, the results of
unit testing can only be of interest if the output _tells_ what one is looking
at, and states (consistently) 'fail' or 'pass', or such.  (time _is_ precious)
anyway, as I said, curious + interested to see how it will all develop.
regards, jr.
Date: 21 Mar 2022 10:25:50
Message: <62388aee$1@news.povray.org>
Le 14/03/2022 à 17:34, jr a écrit :
 > hi,
 >> Hi folks!
forward to
following
 > (potential) issues, and yes, adding a "gripe" or two .
keyword".
'_slice'?  the
'get()' for
be 'oo'
include:
keywords, but
 > common perhaps?)
===> I see these macro names as if they were part of the native
language. Thus, I try to avoid CamelCasing or use underscores as prefix
of suffix.
not do the
 > same, "cleaner"?
 > extend() - not sure how far you will be able to .. bend SDL , but
think that
wrt arrays
array
 >    extend(A,B)
===> You are correct. The use of some PROOF features may (and will)
imply some restrictions. But that's highly secondary for me. In this
particular case, I don't know if Sdl can detect if the array is of fixed
sized. Please, enlighten me.
keyword and
 > brace?
===> Please, precise your mind.
===> I agree that some lines are a bit long. Beautifying detail for now.
===> Why not? Including a *small* file is not a problem. Did you never
#include'ed & C/C++ file or import'ing a python module for just one
symbol? Performance is not in my scope yet, and not significant for such
a small file as colors.inc. Besides, #version'ing has ALWAYS been an
issue and been part of our coding process.
 > unit test output..   without any documentation for yr project, the
results of
is looking
precious)
===> PROOF is in an early state of POC, nothing more at the moment. Sdl
does not ship with an UT engine, as other languages do (eg pyUnit for
Python). So I do what Sdl currently allows me to do quite easily. My
tests are abolutely not ment to be exhaustive. However, they are a
minimum guarantee for myself and the code to be used for the next steps
of the POC, even though they just output text. The output shows the
functionning of my macros. It is no time for developping a UT engine
prior to PROOF, in particular in this phase. Any contributor is
welcome... It is also no time for documenting. Way too early. PROOF
could be a conceptual flop... I try to comment (almost) everything so
that the reader makes a global idea of things I write. I think I added
quite a lot of explanations for where I am now.
 > regards, jr.
Hi. Sorry for the delay. I was on vacation last week without great
possibility for POVing.
Your remarks are welcome and I'll take them into account in a next
version. I also look forward for other people to comment and suggest.
New package including oocore.inc with (pseudo?)unit-tesing coming soon.
Regards
     Bruno
logiciel antivirus Avast.
antivirus Avast.
