![](/i/fill.gif) |
Here is an updated Patina Function to use with Textures (Renamed to
Create_Patina(). Note that I removed the "no_shadow" from the Light Sources
to produce a more realistic result and used some realistic textures. I don't
have the entire rendered image (I'll have to do it again), but I did pull
partial renders to show the possible results (attached). I think it adds a
bit
to include turbulence (more on this later).
// Original Patina() Macro // by Rune S. Johansen 2003
// I don't know that much about how patina should look, but I've got the
// impression that it's not dependent on light source location, like
// subsurface scattering is? If it's more a matter of curvature of the
// surface and nearby surfaces, then this macro might be sufficient:
// Modified by JAC for different effects.
// 1. Renamed function to "Create_Patina" in case changes are made.
// 2. This version uses a Texture_Map instead of Color_Map.
// 3. Can use to create variable color, reflectivity, crand, etc.
// 4. Changed lights to spotlights to improve appearance.
// 5. Added turbulence for effect.
// 6. Amount of textures can be controlled in Texture_Map.
// 7. Notice that when the "Floor" plane is part of the Patina
// Object, colors appear to "bleed" onto it.
// 8. Surfaces perpendicular to an axis are not affected as much
// as non-perpendicular surfaces.
#include "metals.inc"
global_settings {max_trace_level 25}
#macro Create_Patina (Obj,Blur,Samples,Stream)
// By Rune S. Johansen 2003
#local FN =
function {
average
pigment_map {
#local C = 0;
#while (C<Samples)
[1 object{Obj rgb 0, rgb 1}
translate <
rand(Stream)-rand(Stream),
>*Blur
#local C = C+1;
function {FN(x,y,z).red}
// Create Source Object for "Create_Patina"
#declare Object =
union {
plane {y,0}
box {-1,1 scale <3.2,1.0,0.7> translate y}
box {-1,1 scale <1.0,1.0,3.0> translate y}
box {-1,1 scale <0.5,0.7,3.5> translate 0.7*y}
sphere {4*y, 0.85}
torus {2.4, 0.5 translate y}
box {-1,1 scale <1.1, 2.0, 1.1> translate 2*y}
// need to add rotate cube to show how "flat"
// surfaces differ from "non-flat" surfaces.
scale 2
object {
Object
Create_Patina(Object, 2.0, 256, seed(0) )
// turbulence 0.5
// NOTE: This uses a texture_map instead of a color_map
texture_map {
[0/4 pigment {P_Silver1} finish {ambient 0 diffuse 0.6} ]
[1/4 pigment {P_Brass1} finish {ambient 0 diffuse 0.6} ]
[2/4 pigment {P_Chrome1} finish {ambient 0 diffuse 0.6 reflection
0.5 specular 0.5} ]
[4/4 pigment {P_Copper1} finish {ambient 0 diffuse 0.6 reflection
1.0 specular 1.0} ]
[0.10 pigment {color (Blue+Green+White)/5}
finish {reflection 0.4}
// normal {agate 0.01 bump_size 0.01}
[0.30 pigment {color (Blue+Green+White)/5}
// normal {agate 2.0 bump_size 1.0 scale 0.75 accuracy 1e-9}
[0.90 pigment {color (Blue+Green+White)/5}
// normal {agate 4.0 bump_size 2.0 scale 0.75 accuracy 1e-9}
finish {crand 0.5}
// finish {ambient 0.6 reflection 0 diffuse 0.3}
// Set Up Environment
camera {location <9,12,-13> look_at 3*y}
// Sky Sphere (pigmented or plain) /Sky
#declare Sky_Radius = 500000; // Radius of Sky Sphere
sphere { <0.0, 0.0, 0.0>, Sky_Radius*5 translate <0,-Sky_Radius,0>
pigment {granite // omega -0.5 // octaves 8 // lambda 2.0 // omega 0.5
scale 1250000*2 scale <1,0.50,1>*2 turbulence x*0.25
pigment_map {
[0.00 rgb <060,102,175>/255] // Dark Blue
[0.30 rgb <060,102,175>/255] // Dark Blue
[0.80 rgb <199,198,205>/255] // White
[1.00 rgb <199,198,205>/255] // White
finish {ambient 1.0}
finish {ambient 0.3 diffuse 0.0 reflection 0.1}
inverse
no_shadow
scale <100,20,100>
//light_source {< 2, 3,-1>*100, color rgb <1.2,1.2,0.9>*3}
//light_source {<-2, 3,-2>*100, color rgb <0.5,0.5,0.8>*2}
spotlight
point_at <0, 0, 0>
radius 5*10
tightness 50
falloff 8/0.7
spotlight
point_at <0, 0, 0>
radius 5*10
tightness 50
falloff 8*0.7
Download 'patina_00_demo_01.jpg' (98 KB)
Preview of image 'patina_00_demo_01.jpg'
![patina_00_demo_01.jpg](/povray.binaries.scene-files/attachment/%3Cweb.4182fccfd2ef10f0d3c06d7b0%40news.povray.org%3E/patina_00_demo_01.jpg?preview=1)
![](/i/fill.gif) |
