Does anyone have a simple scene file on making a cross or a cricifix? I am
new to povray and I would like to try and make my first scene using a
cross.
Thank you in advance to whomever can help me.
Pauly
Subject: Re: HELP!!!! Crucifix or cross scene file needed please. Tia.
Date: 28 Mar 2005 10:30:29
Message: <42482315@news.povray.org>
pdub nous apporta ses lumieres en ce 2005-03-27 17:57:
> cross.
> Pauly
Use an union of 3 boxes. One big box for the vertical part and 2 for the arms placed
on the sides of
the main one. Use a wood texture with "rotate 90*x" for the first box and "rotate
90*y" for the
other two. You can find many wooden textures in the file "woods.inc", try various ones
until you get
a result that please you. If the scale don't suits you, use a scale on the textures to
enlarge or
shrink the grain.
In article <42482315@news.povray.org>,
>>> cross.
>>> Pauly
>>placed on the sides of
>>"rotate 90*y" for the
>>various ones until you get
>>textures to enlarge or
>>shrink the grain.
>>Alain
why 3 boxes ? 2 are enough no ?
have fun!
Date: 28 Mar 2005 13:43:30
Message: <42485052$1@news.povray.org>
>>>>cross.
>>>>Pauly
>>>shrink the grain.
>>>Alain
> have fun!
I think the reason is to give the overlap in the center a more realistic
look..
i.e. it would be constructed like this:
|vvv|
+----|vvv|----+
|>>>>|vvv|>>>>|
+----|vvv|----+
|vvv|
|vvv|
|vvv|
|vvv|
(Excuse the bad ASCII art)
Where the >> and VV symbols show the direction of the wood grain. If you
overlap the pieces, the two patterns would overlap causing visible
speckling artifacts. If you want it as just a single piece of wood, then
you can get away with just creating a union of two boxes. (or merge, if
you intend it to be a transparent material...)
~Mike
Things! Billions of them!
Date: 29 Mar 2005 09:12:41
Message: <424961D1.2050705@hotmail.com>
>>>>cross.
>>>>Pauly
>>>shrink the grain.
>>>Alain
If the height of the two pieces is the same, which is the
most logical thing to do, you will have a coinciding surfaces
problem. With textures that is sure to look ugly.
Solution: simply offset one a tiny amount.
