POV-Ray : Newsgroups : povray.binaries.scene-files : eval_pigment() and trace() HowTo Server Time
12 Jul 2025 22:28:49 EDT (-0400)
  eval_pigment() and trace() HowTo (Message 11 to 15 of 15)
Subject: Re: eval_pigment() and trace() HowTo
Date: 10 Jul 2016 09:29:00
Message: <57824d9c$1@news.povray.org>
Am 10.07.2016 um 09:00 schrieb Thomas de Groot:
> On 9-7-2016 13:42, clipka wrote:
>> Am 09.07.2016 um 13:17 schrieb Thomas de Groot:
>>> On 9-7-2016 12:38, clipka wrote:
>>>> Am 09.07.2016 um 08:52 schrieb Thomas de Groot:
>>>>> On 7-7-2016 16:02, Bald Eagle wrote:
>>>>>> I see:
>>>>>> #declare WriteStrands = off; //set to 'on' for the first pass.
>>>>>> Isn't there a way to just check if the file exists, and if not,
>>>>>> create
>>>>>> it?
>>>>>> I looked - but it's not clear that this is possible.
>>>>>> Seemed like a useful and desirable feature to be added, if that's the
>>>>>> case.
>>>>> In fact, there is a simple reason why I did not use the file_exists(S)
>>>>> function, now that I think about it. It is that you may want to test
>>>>> different settings before choosing the final ones (at least that is
>>>>> how
>>>>> I work) and so - except for the very first time - there is always a
>>>>> file
>>>>> present.
>>>> You could use something like:
>>>>     #declare WriteStrands = off; // set to 'on' to force re-writing
>>>>     #if (!file_exists(...)) #declare WriteStrands = on; #end
>>> But, that would always set it to on, even when you want it to be off, or
>>> do I misunderstand this?
>> It would always set it to on _if_ the file does not already exist, so
>> you don't need to manually set it to on for the first run.
>> Of course if there are any use cases where you might want to have _no_
>> file at all, then this is of no use.
> I think you misunderstand my use of the on/off switch.
Not at all. But you apparently misunderstand my use of `file_exists()` ;)
> The writing away
> of data is only meant as time saving later on when reading the data
> (always faster than having to do the complete calculations for each
> run). So, the switching off of the writing section (once you are
> satisfied with the written data) is essential. A file_exist switch can
> only make sense to check the existence of a file in the "Read" section
> of the macro.
No, the `file_exists()` test makes perfect sense before the file
generation. It's pretty simple:
- You use `#declare WriteStrands = on;` while experimenting, forcing a
(re-)write on every run.
- You use `#declare WriteStrands = off;` once you're ok, suppressing a
re-write.
- In case the file does not yet exist, the `#if (!file_exists(...))
#declare WriteStrands = on; #end` overrides your choice and forces a
write, thus making sure that the finished scene can be rendered as-is,
with no tampering necessary even if the data file happens to be missing
for some reason.
Date: 11 Jul 2016 02:40:23
Message: <57833f57@news.povray.org>
>>>>>>> I see:
>>>>>>> create
>>>>>>> it?
>>>>>>> case.
>>>>>> how
>>>>>> file
>>>>>> present.
That was a hypothesis I had not considered of course. ;-)
>> The writing away
>> of the macro.
> re-write.
> for some reason.
I see. Not sure if I want to do it that way though. I keep this in mind
for when I 'really' need it :-)
Date: 12 Jul 2016 01:25:00
Message: <web.57847dd1734cd25733c457550@news.povray.org>
> For general information purposes,
> eval_pigment is a macro that is defined in functions.inc as shown below.
> #macro eval_pigment(pigm, vec)
>     #local fn = function { pigment { pigm } }
>     #local result = (fn(vec.x, vec.y, vec.z));
>     result
> #end
It's always been interesting to me that the macro was designed to work only with
the r-g-b color components, and not with the f and t components as well. I
assume there's a reason for that (a technical one?); but evaluating a color like
rgb <.3,.5,.7,.4,.2> will return just the 'opague' colors, not the "colors +
f-and-t mix."
Or maybe my own logic about 'color mixing' is in error, when it comes to
*translucent* color shades (?). I admit that the effects of f and t on a color
are not the same as, say, adding *white* to get a pastel tint. But eval_pigment,
as-is, gives a kind of false result when working with translucency-- or so it
seems.
Date: 12 Jul 2016 02:00:27
Message: <5784877b$1@news.povray.org>
Am 12.07.2016 um 07:20 schrieb Kenneth:
>>     result
>> #end
> f-and-t mix."
And what exactly would make you think so?
If you try it out, you'll find that eval_pigment() works perfectly fine
with full-fledged rgbft colours.
Maybe you somehow got the impression that the `.x`, `.y` and `.z`
referred to the pigment colour's components? They don't. They instead
refer to the input point, passing the individual coordinates as separate
parameters to the pigment function.
Date: 12 Jul 2016 03:06:01
Message: <578496d9$1@news.povray.org>
That is interesting! I did not know that but it makes sense indeed. Good
to know.
